Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th March 2003, 06:06 PM
GUSTAVO GUSTAVO is offline
Registration Date: Mar 2003
Karma Power: 28
GUSTAVO has less than 100 Karma points so far.
Default Process Mapping
I would like to know how is an input/output used in process mapping? wHAT ARE THE INPUTS/OUTPUTS FRO A PROCESS
Example: Reporting production in Oracle system. (Record data)
Example: Exporting material to Mexico.
Thanks in advance,
Gustavo
Sponsored Links
Old 10th March 2003, 09:47 AM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 24
Karma Power: 103
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
Default
Gustavo,
Welcome to the Cove.
I think the easiest way for you to understand the answer to your question is to look at some examples. There are many fine examples of Process maps here on the Cove under various threads. Many are just posted in the last 4 months. Use the search function on the Cove to search for "process maps" in the ISO 9001 section in the last 3-4 months and you will find several threads on this subject. Then, if you still hae a specific question, feel free to post again and ask.
Mike S. ("Gun Nut")
And they ask me why I drink....
Sponsored Links
Old 10th March 2003, 11:14 AM
Nosmo King
Unregistered Guest
Posts: n/a
Default
Mike S. said: There are many fine examples of Process maps here on the Cove under various threads.
But take care, Gustavo!!
Some of the examples I have seen do not at all show the process inputs and the outputs so will do nothing to answer your question.
Best to read the discusions also.
Forgive the intervention, Mike S
Old 10th March 2003, 11:45 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
Gustavo
A good simple guide is to name your processes as verbs, i.e. doing words. Your outputs are quite simply what the process produces, and your inputs are the 'material' required to produce your outputs, and they must be changed by the process. If they remain the same then they are either 'controls' or 'mechanisms', and not strictly (to IDEF0 definition) inputs.
Old 19th March 2003, 10:28 AM
Graeme's Avatar
Graeme Graeme is offline
$ Contributor
Registration Date: Sep 2000
Karma Power: 63
Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.
Send a message via AIM to Graeme Send a message via MSN to Graeme Send a message via Yahoo to Graeme
Question I need to learn ...
I may be having a temporary mental information retrieval problem, so -- can someone please define "IDEF0"? Are there any references I should look at to jog my brain cell loose?
Graeme
Old 19th March 2003, 12:22 PM
Tom Harris
Unregistered Guest
Posts: n/a
Default
Try here Graeme: http://www.idef.com/idef0.html
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? dr madhavan Manufacturing and Related Processes 7 2nd February 2009 02:26 AM
Process Mapping - Process Flow and Interactions of Processes - ISO 9001 michelle8075 Process Maps, Process Mapping and Turtle Diagrams 98 18th June 2008 10:34 AM
Business Process Mapping to comply with TS 16949 - Please review my Process Map mazura Process Maps, Process Mapping and Turtle Diagrams 3 6th June 2006 09:13 PM
Business Process Map - Kindly review my process mapping of my company mazura Process Maps, Process Mapping and Turtle Diagrams 5 16th May 2006 09:33 PM
Process Mapping - I would like your opinions and advice on my process map Hennie Process Maps, Process Mapping and Turtle Diagrams 12 3rd December 2005 01:13 AM
The time now is 04:26 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
