13th March 2003, 10:14 AM
Registration Date: Jan 2000
Karma Power: 41 Karma: 10
Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping?
What is Thermal Mapping? Are there any standards or codes of practices for conducting this with reference to the Heat Treatment Process Furnaces? How frequently is it to be conducted?
Is it to be comparable to 'calibration' requirements?
18th March 2003, 05:57 AM
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 42 Karma: 27
Are you taking about establishing the temperature profile / heat zones within a belt furnace?
We check our belt furnace using a thermocouple a couple of times a year, compare the results to the temperature charts and previous readings.
Hope that helps
Regards
Geoff
The light at the end of the tunnel is an oncoming train - Murphy's Law
18th March 2003, 12:08 PM
I am referring to 'Measurement of uniformity of Temperature across the cross-section as well as in the depath, particularly in 'PIT TYPE' Heat Treatment Furnaces -say, a Gas Carburising Furnace or even a Salt bath furnace.
29th January 2009, 12:22 PM
Involved in Discussions
Registration Date: May 2002
Thanks Given to Others: 2
Karma Power: 33 Karma: 31
The thermocouples then are not used every time but are used to verify that the heat is consistent throughout the furnace. Is that correct?
When you say you compare them to the temperture, I believe your saying the gage outside of the furnace.
Have you ever heard of someone using the thermocouples for each lot during processing?
Where can I find out more about process controls for the heattreating process?
I understand that some suppliers use graphs? I would suppose the graph is a picture over time. Is that correct?
Linda
29th January 2009, 01:22 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Re: Qualification - Heat Treatment Process Furnace - What is Thermal Mapping?
It depends upon what your purpose is. I have seen processes where thermal profile devices go through with every lot, but that's not typical.
Thermal Mapping is taking an oven or furnace and profiling the temperature at different locations. If it's a long furnace line, you would choose multiple 'essential' points and monitor the temperature at each point. If it's a temperature chamber (such as a closed oven) you measure different points within the oven.
Some threads here: Thermal Profiling
Some other Thermal Profile resources.
29th January 2009, 02:37 PM
Re: Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping?
Thank you , Marc
Yes, they are putting the thermocuple (3 of them) through each lot. The product is a shaft for a blender blade. Having never seen a thermocouple, I would think that it is recording the temperture in the differant locations. Right?
I am hearing that we will get charged more for charts , whch makes some sence. However, I would think they are recording data off these thermocouples that should be available for past lots if there is an issue.
Linda
29th January 2009, 03:16 PM
Karma Power: 605
Are the 'thermocouples' traveling on the belt through the furnace, or are they measuring 3 points in an oven (i.e.: three places along the oven, as I assume this is a long belt oven)?
A thermocouple is two pieces of special wire which are welded together. There are different types each of which is for a specific temperature range. The ends of these wires are attached to a measurement device which measures electrical potential. Some people call the wire and the measurement device a 'thermocouple', but I'm from the old days where a thermocouple was the welded wire junction.
Thermocouple
There are devices which are a compact, single 'box' which can be run through an oven with a lot which internally records, or transmits to an external analyzer, the temperature as the device proceeds through an oven with a lot.
I need more specific information on what you're referring to - Spot measurements at places in an oven, or a device which actually goes through the oven with the lot.
** I assume this is a belt oven (long oven). Or, is this one big stationary oven?
2nd February 2009, 02:26 AM
Karma Power: 605
From an email: Hi there
Big statinary oven , atmospherically controlled.
Linda
In those you decide where you want thermocouples, but again it depends upon the oven design. Is it gas or electric? Is there an air mover which keeps air circulating or is it a 'static' oven?
I'm not sure what you mean by atmospherically controlled.
