Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 3.00 average. Display Modes
Old 14th March 2003, 06:27 AM
anilo anilo is offline
Involved - Posts
Registration Date: Mar 2003
Karma Power: 28
anilo has less than 100 Karma points so far.
Default Cpk, Cmk in electronic assembly
someone cal help me?
we design and manifacture electronic engine management system for automotive sector.
Our Client want we define Cpk...
But this seems to be realized for a mechanical process, where i can measure dimension and tolerance, and so i can see either the process is in control or out of control.
But in electronic, where the critical elements are hundreds, what i must measure?
Can I avoid to classify every single defects, and focus only on the Printed circuit which fails?
P.S.: Do you know where i can find standards related to statistic (such as ISO/TR 13425:"Guidelines for the Selection of Statistical Methods in Standardization and Specification" or similar)?
Thanks all
Anilo
Sponsored Links
Old 14th March 2003, 10:28 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
I am not from the automotive sector, but if they want a Cpk, they don't care about all the properties of your product, but your product it self.
for example: How much of the product could be defective? Cpk can be correlated to the ppm defective (if ..., you take the distribution as a gaussian ones.). In the net there are many articles that show such table.
I tink that i'ts right to focus only on the parts that could fail, but keep on mind that they just want a value a Cpk (only one) of your product.
Darius
Sponsored Links
Old 16th March 2003, 04:34 PM
Rick Goodson's Avatar
Rick Goodson Rick Goodson is offline
Registration Date: Aug 2000
Karma Power: 42
Rick Goodson has less than 100 Karma points so far.
Default
anilo,
As Darius implied, Cpk is a measurement of a process not a product. The parameters you mention are not related to the process but to the product. Cpk could be determined for individual processes in your facility. Refernce the AIAG SPC guide for more details. Go to www.aiag.com and look under publications for the SPC manual. It costs $30 for non-members.
Rick Goodson
Old 18th March 2003, 10:08 AM
Involved - Posts
Karma Power: 28
Default
thanks all.
You are right: these are product's item, not process'ones.
but to measure process capability i have to measure how good is its output; and process'output is the product.
Don Winton said:" It is ultimately desiderable to establish control over the process by controlling the process inputs. On the other hand, process capability indices are always performed using the critical parameters of the product" ("process capability studies, 1999, elsmar pdf section downloaded)
So, i think i can list all tipologies of defect, and analyze that with statistical techniques (such as Pareto etc...), but at the end i'll measure how many electronic engine system are fully functional and i extract the Cpk.
But:
1) what's the process mean in such a case?
and what is the data value?
'cause Xbar= Xi/n for i=1 to n
(i think Xi is only Pass/Failure)
2) how can i define LSL and USL ?
remind i have no specifications limits... but the product has to funcion!!
thanks again
Old 19th March 2003, 04:29 PM
Karma Power: 42
Default
anilo,
You are switching back and forth from attribute and variables during your discussion. An X-bar chart is a variables control chart where pass/fail data is attribute data. You cannot plot attribute data on a variables control chart.
From the AIAG SPC 1995 publication:
Process capability is the total range of a stable process's inherent variation: 6 sigma cap sub R/d2.
For attribute data:
Process capability is usually defined as the average proportion or rate of defects or defectives. From control charts (p,c,u), for example, capability is defined as p-bar, c-bar, or u-bar where capability refers directly to the average proportion or rate of output that does not meet the specification (or as 1- p-bar, etc. the percentage of product within specification.
Ford use to use 99.994% as the minimum process capability for an attribute control chart based process capability calculation. That is, 99.994% of product had to meet the specification. I do not know if that is still a good number or not.
In essence, the ccapability is the first pass yield on the complete process.
Hope this helps.
Rick Goodson
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
A question about Cpk and Cmk - Can we use Cpk to replace Cmk? sunwen Capability, Accuracy and Stability - Process, Machine, etc. 1 11th April 2007 08:45 AM
Some questions about Cmk and Cpk Hennry Capability, Accuracy and Stability - Process, Machine, etc. 2 14th May 2005 02:20 PM
Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc. Cemm Mex Capability, Accuracy and Stability - Process, Machine, etc. 5 21st June 2004 09:28 PM
Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Stevenli Capability, Accuracy and Stability - Process, Machine, etc. 3 20th August 2003 09:18 PM
Any ideas on setting up Capability study spreadsheet in Excel?(CPK/CMK formulae) bagpuss Excel .xls Spreadsheet Templates and Tools 4 2nd March 2001 11:39 AM
The time now is 07:59 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
