1st April 2003, 04:00 PM
$ Contributor
Registration Date: Dec 2001
Thanks Given to Others: 3
Karma Power: 39
Transition of Quality Management - Recently lost our Quality Manager
We have just recently lost our Quality Manager, and are planning on how best to fill the gap. As we go through this transition period, how long a 'grace' period - if any- can we expect from the registrars for getting documentation updated to reflect new ownership of responsibilities? - What has to be in place by 'tomorrow', and what could wait until the dust has settled? - Our next maintenance audit is scheduled for 6 weeks from now, so I have a bit of time to get the initial documentation changes made.
I am sure many of you have inherited positions from former QA managers. I would be most interested to learn how you handled the transition, what pitfalls to avoid, and the damage control that needs to be done right away.
Many thanks,
Barb
1st April 2003, 04:16 PM
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 283
Karma Power: 171
barbt:
There are several considerations here, and many depend on how good a job the departed QM was doing.
One thing to look out for is documentation that mentions a person's name or initials. Now, I don't mean a signature, but within the document if "Sammy Quality" is mentioned instead of "Quality Manager", then those will all have to be changed.
In the cases where the departed QM has singed off on something, leave it in place. If he was the QM on the date the signature was made, it is OK.
It is going to take anyone new a while to learn what system is already in place. Since you mentioned a maintenance audit, I assume your system is presently in good shape. Then, in the interm, someone needs to be appointed for each of the areas (i.e. corrective action) that require ongoing attention.
You didn't mention if you have made the transition to 2000. If not, someone needs to start addressing that now.
Hope this helps.
Craig
1st April 2003, 04:21 PM
Registration Date: Mar 2000
Karma Power: 51 Karma: 114
Hmmmm??? much of this actually depends on the viewpoint of your specific registrar but without knowing any specifics within your particular system ......
If the documents were set-up in a maner that allowed smooth transition (IE using job titles to assign responsibilities instead of actual designated names) the transition should not be all that problematic
Resign & re-print the Master Hard copy - change/update the electronic copies and go from there.....
Be prepared to identify the Date the job was given to the "new Qa manager" and I would THINK any auditor would work with you on it
Hope this helps
Regards
Jim
"Chance is a word void of sense; nothing can exist without a cause."
Voltaire
1st April 2003, 04:37 PM
Courtesy Access
Registration Date: May 2001
Karma Power: 67
You might want to have executive management issue a letter/memo stating who is taking over the responsibilities of the quality manager in the short term. If the duties are being split among several people, it will help explain why approvals may not look right against the documentation. I agree that if you are not using titles on procedures you should change, but the memo above will cover you in the short term.
I've had clients transition quality managers within a few weeks of an audit. It was looked on as corrective action / continuous improvement since the first QM was not doing a good job. Most auditors will be fine if there are some difficulties with the new person explaining things, as long as everything is still being done properly. Don't try to rely on "I didn't know we were supposed to do that since I am new." - If your procedures are good it will help the transition.
Tom
1st April 2003, 06:34 PM
$ Contributor
Karma Power: 39
My thanks to all of you who have replied.
The good news is that our documentation does reflect titles and not names, and that we are planning an announcement of official transition for this week.
- This is a relief, I was doing some heavy research into the QS9000 manual to see what is written with respect to management representative transition. I wasn't completely sure how this should be handled. It sounds like I have some breathing room until it's sorted out.
thanks,
Barb
1st April 2003, 07:44 PM
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Barbt,
I'm not sure how your systems work, but do you have a Management Represetative that should already be able to answer you question!
"Para ... Bellum"
1st April 2003, 09:17 PM
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
This is an important note Tom. If your system is working properly, your new person should slide in rather seamlessly. Most auditors will give a little bit of slack in finding the evidence (knowing which file drawer it is in), but don't look for slack in knowing what was supposed to happen.
Al raises a good point here. I think we are all assuming your Quality Manager and your Management Representative (MR) are the same person. This might not be the case, in which your MR should have things under control
Dave B (the other Dave)
4th April 2003, 04:53 PM
Courtesy Access
Registration Date: Jun 2002
Thanks Given to Others: 21
Karma Power: 66
Hi Barb,
I understand you dilemma, having been through the same scenario recently.
At the end of January, we went through a massive reorganization. Several departments went away to other facilities, and the Quality Director in my facility was laid off and the job transferred to a division 2000 miles away.
I'm the ISO Rep, so at least we didn't lose total track of how the QMS works here, but I had an ISO audit coming up which included several of the depts. we'd axed.
The very first thing I did was contact my assessor and explained what had just happened. That way he was prepared to come in and "punt" as it were.
Next I met with division management and asked them to do a review of the documents from the affected departments and put together a roadmap for reviewing, updating or withdrawing them. I knew it would be impossible to do everything before the audit, but a roadmap shows planning. Every company has periods like this where changes are happening quickly. As long as there is communication with the assessor and a control plan for how the changes will be handled, I don't think any reasonable auditor would take you to task. After all, by doing this you're demonstrating that you're controlling the integrity of your system during periods of changes, just as 5.4.2 requires.
My audit was earlier this week and it went fine.
Good luck!
Rosie A
Warrior Goddess of Quality
