Elsmar Cove Quality DiscussionsMeasurement - Pressure Drop vs. Leak RateThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
leak test, measurement techniques and procedures
Reply
  Post Number #1
Old 9th October 2013, 11:42 PM
GURU SDI's Avatar
GURU SDI
Please Help! Measurement - Pressure Drop vs. Leak Rate
Hi all,
I want to measure a leak rate (air) for my assembly. In my technical drawing, it is specified as "X ccm" at testing pressure (P) for a testing time "t" secs.
But My supplier having an instrument which measures leak rate as pressure drop instead of actual leak rate. now i want to give allowable pressure drop for the leak testing process.
Kindly provide your inputs.
thank you
Sponsored Links
  Post Number #2
Old 10th October 2013, 05:49 AM
rob73's Avatar
rob73
Re: Pressure Drop Vs Leak Rate
Guru
See http://newsletters.inficon.com/LEAKT...techtalk1.html this give the formula to convert pressure drop to leakage rate and vice versa
  Post Number #3
Old 10th October 2013, 01:43 PM
Bev D's Avatar
Re: Measurement - Pressure Drop vs. Leak Rate
Alternativley you can develop the formula for yourself by performing a straight forward correlation study.
first select some parts (30 if possible but no fewer than 10 if they are rare)
have yourself and the supplier measure each unit twice.
determine the repeatability of your system and the supplier's system.
if both systems are sufficiently repeatable perform a regression on the first measurement made by yourself and the supplier - this wil give you the conversion formula based on the exact specifics (uniqueness) of each system.
  Post Number #4
Old 10th October 2013, 02:11 PM
GURU SDI's Avatar
GURU SDI
Thanks Rob...
But this equation is arrived based on the perfect gas equation, which assumes the process takes place under constant temperature (practically temp is not constant during my test) and moreover i am having difficulty in measuring the exact volume of my test piece.
so i planned to take the readings in both pressure drop and leak rate for 50 samples.. & there should be linear relationship between these two variables...so I can arrive best line of fit between leak rate and pressure drop...
From the straight line equation, i my get pressure drop...
Any other views to measure...thanks in advance
  Post Number #5
Old 10th October 2013, 02:15 PM
GURU SDI's Avatar
GURU SDI
Thanks Bev
Please see my post, will my study give good result..
Provide your inputs
  Post Number #6
Old 10th October 2013, 04:33 PM
gpainter
Compressed air should be looked at as a system. Use an ultrsonic leak detector to find leaks. Pressure drops can be a result of many different things, distance,couplings, etc. Develope a leak detection system. A single 1/16 leak can run about $732 an year based on $0.07kWH and up to 30% of compressed air is consumed by leaks. Compressed air is also not an energy efficient power source(5-10% at most)and costs 6-8 times the cost of electric.
  Post Number #7
Old 10th October 2013, 08:21 PM
dgriffith
If I have a closed system with 10 psi in it, and I measure the pressure again after 5 minutes and I have 8 psi in it, what is my average leak rate? I think it is 2 psi/5 minutes which is 0.4 psi/min.
When I connect an Air Data Test Set up to an aircraft and perform a leak check on the pitot-static system, I'm going to get pressure per unit time (or altitude or airspeed/time), and I'm not going to care about the volume of the system--Piper Cub or 787. The test set doesn't care.
What is of concern are the variables--most important being adiabatics. Unless the system is temperature stabilized, gas temperature changes will cause pressure changes--for a given volume--that will mimic a leak. Leak checks performed immediately after evacuation or pressurization will run that risk.
So, as a baseline, I would pressurize the system, wait 60 seconds, and measure/record the pressure every minute for 5 minutes. I would plot the values and see how curvy it was. Too curvy at the top means wait longer before starting to record. If it's not too curvy, then establish a 1st order slope (regression line). You could then predict a pressure leak anywhere along the line for a given time.
In other words, for a 2 minutes leak check x, after waiting to stabilize, you should get a pressure value y ?some error.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
FDA Blood Pressure Monitoring Equipment Measurement Requirements acro14 US Food and Drug Administration (FDA) 1 24th September 2014 01:07 PM
Validation of a Pressure Decay Leak Tester for a Medical Device baezes Design and Development of Products and Processes 1 17th January 2013 05:05 PM
Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? nurhakim 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2 23rd October 2011 01:58 AM
Rejection rate statistical measurement siouxan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2 2nd July 2009 12:16 AM
Effectiveness, miss rate and false alarm rate - Need formulas to calculate nurcan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 18th April 2007 01:49 AM
The time now is 01:25 AM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
