Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Software Quality Assurance
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th April 2003, 05:48 PM
RosieA's Avatar
RosieA RosieA is offline
Courtesy Access
Registration Date: Jun 2002
Thanks Given to Others: 21
Karma Power: 66
RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.RosieA is appreciated, and has over 1100 Karma points.
Default Waterfall vs Life Cycles
Can anyone provide comparison of the waterfall method of software development vs the Life Cycle method?
Pros and Cons?
Rosie A
Warrior Goddess of Quality
Sponsored Links
Old 11th April 2003, 08:33 PM
Nosmo King
Unregistered Guest
Posts: n/a
Default Re: Waterfall vs Life Cycles
Pros and Cons?
Rosie -- that’s a big (and very interesting) question – this is just a quick starter answer.
The Waterfall is just one method of organising a software development life cycle – see a basic overview of approaches here: http://www.augustana.ab.ca /~mohrj/courses/2000.winter/csc220/presentations/ch12lect/
Two ISO standards apply:
ISO/IEC 12207 Software Lifecycle Processes --
overview at http://www.stsc.hill.af.mil/crosstal.../08/isoiec.asp
ISO 9000-3 (application of ISO9000:2000 to software)
I hope that helps a little!!!
Sponsored Links
Old 14th April 2003, 09:28 AM
RosieA's Avatar
Courtesy Access
Karma Power: 66
Default
The first site, in particular...I appreciate the direction.
I have ordered ISO 12207 and the Tickit Guide, but plainly written overviews with positives and negatives really help a lot.
Rosie
Rosie A
Old 17th April 2003, 12:29 PM
RosieA's Avatar
Courtesy Access
Karma Power: 66
Default
I have received a copy of ISO 12207 on Life Cycle Processes, and have a semantic question.
In section 5.3.1.1 the standard states that the developer shall define or select an appropriate software life cycle model
Under definitions, a life cycle model is defined as a framework containing processes, activities, and tasks involved in the development, operation and maintenance of a software product.
Then there's a graphic in section 4 showing Primary Life Cycle Processes. Are these primary processes what they're talking about selecting? I'm confused by the terminology...is a process the same as a model?
It seems to me that I'd choose the Development Process as my model...is that correct?
Sorry to be thick...reading standards can be confusing.
Thanks,
Rosie
Rosie A
Old 25th August 2003, 06:54 PM
Godfrey Partridge Godfrey Partridge is offline
Registration Date: Aug 2003
Karma Power: 27
Godfrey Partridge has less than 100 Karma points so far.
When aquiring software you need to consider the steps or milestones involved in the process. A simple process would be
"enter shop, see boxed software, purchase, install, operate
a More complicated process would be
Specify aplication, develope purchase/aquisition specification, develop contract enquiry, selection of vendors, place contract, commence development high level design, modul design, software item design program assembly, test prescription, installation, test commission, delivery support, maintenance and operation.
Someware between the two an option suitable for a given aplication exists and it is required of the purchaser to determin what items should make up the process when initialy developing a software aquisition project.
This is what ISO12207 and Tickit are driving at when they call for selection of life cycle.
Hope this helps.
Enjoy
Godfrey
Old 29th October 2003, 09:02 AM
mdumont mdumont is offline
Registration Date: Jul 2003
Karma Power: 26
mdumont has disabled his/her Karma.
Default
I usually make the following difference between a process and a lifecycle, based on the state/transition diagram and Object Oriented technoogy.
A process is a suite of interrelated activities that create or transform a "product". A product may be a request document, a written document, a mechanichal part, a software, and so on.
The life cycle describes the successive states of the product as it is transformed by one or several successive processes, from an initial to a finished state.
In the software industry, the "software development process" transform a set of requirements into an executable application. Just identify the software as a product and transform it from its initial state "requirements" into a finished state "application". You have intermediate state like "designed", "coded", "tested",...
If you represent that in a diagram, with boxes and arrows linking the boxes, the process diagram represents activities in the boxes and the product in specific states in arrows. The lifecycle diagram repersents product states in boxes and transformation activities in arrows.
In the software methodology litterature unfortunately, when you see a "waterfall lifecycle", it's generally the description of a process, not a life cycle. (at least in my opinion).
To answer your question on the term "model", it is the description of a generic "process" or "lifecycle" that is customized to represent your particular needs. You plan your activities with one model or the other but you keep the model in mind.
Does it help?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Software Design SOP to ISO 62304 (Software life cycle for Medical Device) ISO 13485 - Medical IEC 62304 - Medical Device Software Life Cycle Processes 3 15th August 2009 09:56 AM
IEC 62304:2006 Medical device software - Software life cycle processes - Issued wrodnigg IEC 62304 - Medical Device Software Life Cycle Processes 10 23rd June 2009 11:35 AM
Life Cycle - ISO 12207 - Software development activities Marc Software Quality Assurance 4 24th March 2008 12:06 PM
IT Software Life Cycle Development - How do 7.3.2 to 7.3.4 apply? HPLJJ Software Quality Assurance 5 29th October 2006 10:55 PM
Software Life Cycle - Software Development Procedure HellenK Software Quality Assurance 2 7th August 2006 03:19 PM
The time now is 03:10 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
