Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 31st January 2000, 11:03 AM
Karen
Unregistered Guest
Posts: n/a
Let Me Help You Weld Inspection of Assemblies - Agricultural spreaders manufacturer
We manufacture agricultural spreaders for lime and fertilizers. Parts are fabricated (sheet metal) and welded according to customer specifications. We currently do not have any criteria for Weld Inspection. Our lead people bring an experience level to know when a weld is "good" but we want to document some criteria to incorporate into Measurement and Monitoring of Product. We would hope to satisfy the requirement with visual inspection. This is what we have so far.
* No Weld Cracks
* No Cold Lap
* No Undercuts
* No Overlap
* Proper Fusion/Penetration
* Adequate Fillet Size
* Alignment of Parts (per drawing spec)
* Even/Clean Weld
Do we need to be more specific? Do we need to define to some sort of standard regarding fusion and fillet size? We don't need rocket science, but want to be measureable.
Thanks As Usual!
Sponsored Links
Old 31st January 2000, 05:00 PM
Tom Goetzinger Tom Goetzinger is offline
An Early Cover
Registration Date: Mar 1999
Karma Power: 0
Tom Goetzinger has less than 100 Karma points so far.
Welding is normally defined as a "special process", in that it is only through destructive testing that the quality (strength) of the weld can be determined. For that reason,I would caution use regarding inspection criteria, unless it is the cosmetic aspects that you are concerned with.
I would suggest relying on the skill of your operators as opposed to inspection. We covered special processes in our procedures, indicating that those functions could only be performed by certified operators or operators in-training. Those in-training work under the direction of those certified and are allowed to perform those type of operations at which they have become proficient.
Sponsored Links
Old 31st January 2000, 07:48 PM
Randy's Avatar
Randy Randy is offline
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Randy
I believe there are some ANSI specs governing welding. Also check some professional organizations for accepted criteria.
I used to inspect aircraft welding and you're right farm equipment is not rocket science.
Old 15th February 2000, 06:09 PM
KWZPENG
Unregistered Guest
Posts: n/a
You might want to use ANSI/AWS D9.1-90 Standard Sheet Metal Welding Code as a guideline. It includes:
-General Provisions for Arc Welding
-Arc Welding Procedure Qualification
-Qualification of Arc Welders and Arc
Welding Operators
-Arc Welding Workmanship
-Inspection of Arc Welding Work
Old 15th February 2000, 07:24 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Quid Pro Quo
When you go to ANSI's site and enter welding, 50 something documents appear. These include:
SS-EN 729-4
Quality requirements for welding - Fusion welding of metallic materials - Part 4: Elementary quality materials $ 28
SS-EN 729-3
Quality requirements for welding - Fusion welding of metallic materials - Part 3: Standard quality requirements $ 40
SS-EN 729-2
Quality requirements for welding - Fusion welding of metallic materials - Part 2: Comprehensive quality requirements $ 40
SS-EN 729-1
Quality requirements for welding - Fusion welding of metallic materials - Part 1: Guidelines for selection and use
Good hunting.
Old 15th February 2000, 07:42 PM
gmac
Unregistered Guest
Posts: n/a
I Say...
Without getting too deep into the welding/materials side of things, you could look at having one of your personnel qualified as a visual inspector, as long as your customer isn't expecting non destructive examination at a higher qualification level i.e. magnetic particle or radiography visual inspection to a recognised standard should suffice.
Old 16th February 2000, 10:07 PM
Jase Eyre
Unregistered Guest
Posts: n/a
Question
In a recent post on Welding Inspection, Tom Goetzinger replied with the following:
My question is this: Is there such a thing as a "Special Process" in the 2000 revision, or is this a term devised by an individual company? I can find no reference to this concept in the Standard.
In my industry (building design), the outcome of the design process likewise cannot be tested through traditional 'inspection' regimes (short of trying to knock down new buildings), but must rely on the skill of the designers. What implications does this have for compliance? How can we prove we've followed the relevant building standards short of documenting everything with checklists? Or can we rely on the fact that our designers are highly qualified, highly competant professionals?
...Or am I just confusing the issues (probable, given the day I'm having!)?
In fact, I think I'll go and have a lie down...
Old 17th February 2000, 10:36 AM
An Early Cover
Karma Power: 0
Jase,
This is something our registrar asked us to address. He referenced it to 4.9.g. My impression was that the term "special processes" was quite commonly used to refer to processes which cannot be validated except by destructive testing, but maybe that is a United States thing. You are right that specific term are is not specifically used in the standard.
Tom Goetzinger
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Visual Weld inspection training RayZ-Insp Inspection and Test, Sampling and Related Topics 1 22nd July 2008 12:02 PM
Inspection Criteria for Foreign Objects in LCD Assemblies needed normzone Various Other Specifications, Standards, and related Requirements 2 21st August 2007 01:22 PM
Calibration Standard N24: PFM NO 1841 - Ultrasonic Inspection of Resistance Spot Weld Dana Stout Documentation Control Systems, Procedures, Forms and Templates 1 24th September 2005 12:06 PM
Weld Stepper Validation in production weld-cells dtrebel Preventive Action and Continuous Improvement 6 2nd November 2004 07:05 AM
Quality plan / R&M format - Welding assemblies, hemmer assemblies, fastening systems mibusha APQP and PPAP 2 19th December 1998 12:29 PM
The time now is 11:22 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
