Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th May 2003, 05:56 AM
Geoff Cotton's Avatar
Geoff Cotton Geoff Cotton is offline
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 42
Geoff Cotton has less than 100 Karma points so far.
Let Me Help You Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories
Minitab is giving me different results for distinct catagories when analysing GR&R data through the XBARR method then by ANOVA.
Any ideas why?
Regards
Geoff
The light at the end of the tunnel is an oncoming train - Murphy's Law
Sponsored Links
Old 10th May 2003, 10:19 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Lightbulb
Without looking at the data, it is difficult to say. Does your ANOVA table show a significant Part*Appraiser interaction?
ANOVA calculations would be more accurate since Range-Average method does not take interaction into consideration.
-Atul.
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Sponsored Links
Old 23rd May 2003, 05:28 AM
Courtesy Access
Karma Power: 42
Default
Atul,
Sorry for thr delay in my reply, we have just had our TS audit so I was took out of the frame for a few days. (We have five minors.)
Looks like I can't attach a Minitab File so I've included the data below. The distinct catagories says the study fails i.e DC's = 2 using the ANOVA method. I think I know why, but would like to hear your thoughts.
The total tolerance for the part is 0.2mm
Thanks in advance
measurment sample operator
4.954 1 A
4.967 2 A
4.992 3 A
4.923 4 A
4.972 5 A
4.954 6 A
4.980 7 A
4.959 8 A
4.970 9 A
4.988 10 A
4.955 1 A
4.972 2 A
4.994 3 A
4.922 4 A
4.957 5 A
4.971 6 A
4.974 7 A
4.971 8 A
4.968 9 A
4.968 10 A
4.957 1 A
4.974 2 A
4.998 3 A
4.923 4 A
4.972 5 A
4.956 6 A
4.974 7 A
4.959 8 A
4.973 9 A
4.986 10 A
4.971 1 B
4.973 2 B
5.007 3 B
4.921 4 B
4.965 5 B
4.971 6 B
4.974 7 B
4.971 8 B
4.969 9 B
4.982 10 B
4.971 1 B
4.971 2 B
5.004 3 B
4.928 4 B
4.968 5 B
4.972 6 B
4.978 7 B
4.971 8 B
4.960 9 B
4.989 10 B
4.960 1 B
4.972 2 B
5.005 3 B
4.926 4 B
4.969 5 B
4.979 6 B
4.979 7 B
4.974 8 B
4.970 9 B
4.988 10 B
4.943 1 C
4.954 2 C
4.932 3 C
4.925 4 C
4.956 5 C
4.972 6 C
4.976 7 C
4.964 8 C
4.969 9 C
4.973 10 C
4.956 1 C
4.969 2 C
4.988 3 C
4.929 4 C
4.967 5 C
4.976 6 C
4.976 7 C
4.967 8 C
4.972 9 C
4.964 10 C
4.970 1 C
4.963 2 C
4.994 3 C
4.922 4 C
4.962 5 C
4.956 6 C
4.979 7 C
4.968 8 C
4.964 9 C
4.975 10 C
Regards
Geoff
Old 26th May 2003, 09:57 PM
CristiánC CristiánC is offline
Registered Visitor
Registration Date: Jul 2001
Karma Power: 36
CristiánC has less than 100 Karma points so far.
Default Minitab R&R
Geoff:
Let me add my 5 cents, because I guess I can help you a little.
Number of Distinct Categories: NCD is calculated as
(ProcessSTDEV / MeasSTDEV)*1,41
By analyzing your data, is easy to notice that for ANOVA ProcessSTDEV = 0,0169 and MeasSTDEV = 0,00999. On the other hand, for Xbar/R, ProcessSTDEV = 0,0208 and MeasSTDEV = 0,00765.
For ANOVA, the NCD = 2,38 and rounded to nearest integer = 2.
For Xbar/R the NCD = 3,83 so = 4.
The difference between the exact NCD values is not too big (and leads you to the same decision, according to AIAG manual).
The additional problem here is related to the way that Minitab has rounded each one of the values (in opposite directions).
Differences in STDEVs are consequence of different methods of estimating sigma, but the differences in your example are not too big...
Hope this helps!
Old 27th May 2003, 04:55 PM
Forum Administrator
Karma Power: 90
Default
Geoff,
I tried to analyse the data using my own software. Attached are two report files: 1. ANOVA calculations with interaction (charts included) and 2. Range-Average calculation.
Though you do have a choice of using either ANOVA or Range-Average, ANOVA is said to be a more accurate estimate. The Range Average method uses RBar/d2 method for estimation of variation and ANOVA uses Sum Squares (first principles, if you like).
Look at the readings of Appraiser C (esp. Part 3, Reading 1). This is very different from the other 8 readings for this part. Also observe the XBar and R Charts for the operators and the interaction plot. There is clearly an assignable cause for this error (may be improper method, or just carelessness!). There is a large variation in measurements by this operator. This probably is why ANOVA shows an interaction. (I still have an issue whether this interaction should be shown separately as significant or should it be pooled with EV - of course, either way it does not affect the DC much.) In Range Average method, this will inflate the repeatability error. If you were to change this one reading to, say. 4.992, you would get better value of nDC.
In Range Average method, since interaction is not separated, a part of it gets confounded with PV, hence a larger value of nDC (as compared to ANOVA).
Looking at the data, I also noticed that the total range of data is 0.086 which is much lower than the tolerance of 0.2. There can be two reasons for this: 1. Process Capability Cp is high and selected parts represent the entire process spread OR 2. Part selection is wrong - it does not cover the entire tolerance range. This may be one reason, GRR makes up a large percentage of PV.
-Atul.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Gage R&R or Anova two way? Using Minitab ed1978 Using Minitab Software 1 14th October 2009 08:23 PM
NDC (number of distinct categories) - Long Gage R&R Study in MSA 3rd Edition YKT Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 37 30th September 2009 01:14 PM
Interpreting Minitab Gage R&R study results - Relative Crease Strength (RCS) Cambo Using Minitab Software 3 25th January 2009 08:36 PM
Unilateral Gage R&R (GR&R) - Minitab 13 - Does this study pass or fail and WHY? justncredible Using Minitab Software 17 12th December 2006 06:47 AM
Distinct data categories - [PV / R&R] - May I know what is this equation used for? match_stick82 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 5th October 2005 02:02 AM
The time now is 11:35 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
