Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st May 2003, 06:13 AM
lee01 lee01 is offline
Courtesy Access
Registration Date: May 2001
Thanks Given to Others: 2
Karma Power: 36
lee01 has less than 100 Karma points so far.
Default Calculating the RFT using the Cpk value
Help needed:
I understand that if your Cpk value is 1.33 your looking at a RFT value of 99.9937%. and if you have a Cpk of 0.50 your looking at a RFT value of 86.64%.
This is on most documentation out there but, is there a formula that I can use to create the actaul RFT for all my measured processes? I do not want to guess what a RFT value is simply by comparing the documentation and guessing what RFT value I have if I have a Cpk of 0.43 etc. . .
Best Regards
Lee01
Sponsored Links
Old 21st May 2003, 11:34 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
My recomendation is not to use any relation RTF vs Cpk, as Don Wheeler said, the Cpk take in account "normality" (Gausian distribution, I hate the term "Normal", because most of the people tink, is what it should be, if no special causes happen), and as more the distributions departure of "normality" happen, the estimated values get garbage.
There are may tables of such relationship on the net (and in some books, like "Inovative Control Charting" by Stephen A. Wise and Douglas C. Fair).
If you still want to do it, use a interpolation of the table shown of the file, I once obtain an aproximate formula
dpm (1 tail ) = Exp( - 5.356 * Cpk^1.859 + 12.581))
in the two tails case, multiply the result by 2
and RFT= 100 - dpm / 10000
beware: Deming (1986):“no process,except in artificial demonstrations by use of random numbers,is steady and
unwavering".
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 21st May 2003, 01:20 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
Doesn't that number come straight from a "standard normal" table? It should be easy to come up with the RFT number using the table and an understanding of Cpk. Like Darius implies though, you need to know if the distribution is normal and if it is centered in the tolerance or not. To calculate the real value, you would need to know not just Cpk, but also the mean, standard deviation, and the specification limits.
Old 21st May 2003, 01:23 PM
Al Dyer's Avatar
Al Dyer Al Dyer is offline
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.
Send a message via AIM to Al Dyer
Default
Aren't the two mutually exclusive since there is no direct relationship?
Just enquiring?
Al...
"Para ... Bellum"
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calculating Cp and Cpk on a Non-Normal Distribution Andrews Capability, Accuracy and Stability - Process, Machine, etc. 14 21st April 2009 08:50 PM
Calculating Cpk on a single sided (unilateral) tolerance lee01 Capability, Accuracy and Stability - Process, Machine, etc. 22 27th January 2009 10:54 AM
Use of an outlier in calculating Cpk/Ppk duecesevenOS Capability, Accuracy and Stability - Process, Machine, etc. 8 10th August 2006 09:50 AM
Cp & Cpk - How are you calculating the standard deviation? MSHELLEY Capability, Accuracy and Stability - Process, Machine, etc. 3 19th February 2001 07:35 AM
Calculating Defect Rate (PPM) from a Cpk value Marc Capability, Accuracy and Stability - Process, Machine, etc. 8 17th January 2001 04:34 PM
The time now is 03:06 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
