Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Design and Development - Process and Product
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 16th June 2003, 08:15 PM
johnnybegood johnnybegood is offline
Involved - Posts
Registration Date: Jun 2001
Karma Power: 37
johnnybegood has less than 100 Karma points so far.
Look! Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan
We have a production with a run rate of 1k per shift. Production manually assemble the product and have it tested electrically at test station. Before the product is send for packing, Production will 100% visually inspect for mechanical/cosmetic defect. QA inspector will do sampling buy-off electrical and mechanical/cosmetic.
The product does not come to QA in a constant rate. My question is how do I generate a correct sampling plan? Customer goal is 0.08dphu
Thanks to johnnybegood for your informative Post and/or Attachment!
Sponsored Links
Old 17th June 2003, 01:05 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
I'd probably set up a sampling plan based on ANSI/ASQ Z1.4 since it sounds like you're doing attribute sampling. MIL-STD-105E is equivalent to that standard, and you can download it free: Free Military Standards.
Sponsored Links
Old 17th June 2003, 02:10 PM
Al Dyer's Avatar
Al Dyer Al Dyer is offline
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.
Send a message via AIM to Al Dyer
Default
Yes,
105-E is very good and there is also a good one in Juran. The important aspect, in my opinion, is that these guidelines and tables can be modified from their original content to work with any company specific situation.
The thing is not where it is from, but if it works.
Great guidelines
Al...
"Para ... Bellum"
Old 19th June 2003, 05:41 AM
Involved - Posts
Karma Power: 37
Default
How to set or determine the AQL and which inspection level?
Old 19th June 2003, 01:14 PM
howste's Avatar
Thaumaturge
Karma Power: 206
Default
From MIL-STD-105E page 2:
Use of a value of AQL for a certain defect or group of defects indicates that the sampling plan will accept the great majority of the lots or batches provided the process average level of percent defective (or defects per hundred units) in these lots or batches be no greater than the designated value of AQL.
So what you want to do is find the AQL closest to your customer's requested AQL (which is the same as DPHU) of 0.08. The options you have are 0.063 or 0.10. I'd probably play it safe and pick 0.063. You can look at the OC curves in the standard to see if it makes sense.
Normally inspection Level II is used. Other levels can be used depending on the sampling risk.
Old 15th July 2003, 05:51 AM
Involved - Posts
Karma Power: 37
Default
Let say my customer does not spell out the dpku goal. Now how do I set a sampling plan then? I really do not know where and how to start.
Old 15th July 2003, 09:32 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Food for thought;
If production is already doing the testing and visual inspection, what is the need for an additional QA inspection?
Sam Goody
Old 15th July 2003, 08:19 PM
Involved - Posts
Karma Power: 37
Default
Originally Posted by Sam
Food for thought;
call it escapee.......Production may not be testing/visual inspection 100% eventhough they are suppose to do so. Visual inspection are manually human dependent thus defect may skip thru.
Reply
Bookmarks
Tags
ansi/asq z1.4, mil-std-105, sampling plan
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? AndyN SPC Monitoring and Statistical Analysis Techniques 4 15th October 2008 10:35 PM
Acceptable AS9100 Receiving Inspection Sampling Plan - ANSI/ASQCZ1.4 vs. Mil-STD-105E tomstwincam AS9100 Aerospace Standard and Requirements 10 6th November 2007 06:10 PM
AQL for Laymen - ANSI/ASQ Z1.4 - MIL-STD-105 The Fixer AQL - Acceptable Quality Level 18 12th June 2006 08:51 AM
Why '105' and '414' in the military sampling plan standards (Mil-Std-)? cpgonzal Philosophy, Gurus, Controversy and Evolution 1 8th January 2004 02:07 PM
The time now is 11:37 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
