Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th June 2003, 06:31 AM
lee01 lee01 is offline
Courtesy Access
Registration Date: May 2001
Thanks Given to Others: 2
Karma Power: 36
lee01 has less than 100 Karma points so far.
Thank You! What is the Formula for Cpk in Excel?
Can someone inform what the Cpk formula I should be using in excel?
I'm currently using:
=IF(B11<B12,B11/3,B12/3)
Converted: If(0.351<2.921,0.351/3,2.921/3)
I'll tell you what, I'm taking a full sample of points and have these values, anyone want to give me an idea how to calculate the value?0.0166
0.0073
0.0003
0.0078
0.0039
0.0138
0.0033
0.0101
0.0008
0.0009
0.0114
0.0129
0.0021
0.0053
0.0173
0.0139
0.0021
0.0007
0.0118
0.0126
0.0019
0
0.0124
0.0123
-0.0036
0.0145
0.0088
0.0101
0.0068
0.0089
0.0178
0.0014
0.0136
0
0.0138
0.0141
0.0023
0.0143
0.0172
0.0038
0.0084
0.0234
0.0129
0
0.0011
0.0119
0.0111
0.0023
0.0039
0.0092
-0.0018
0.0073
0.0014
0.004
0.0116
Mnay many many thanks
Lee01
Sponsored Links
Old 19th June 2003, 11:06 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
I don't recognize the equation. How did you get there?
Sam Goody
Sponsored Links
Old 19th June 2003, 11:13 AM
Craig H. Craig H. is offline
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
Craig H. is appreciated, and has over 1700 Karma points.
Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.
Default
Lee:
Why don't you put the data in an Excel file and attach it to a thread?
I assume the spec is .351 min, 2.921 max?
Old 19th June 2003, 12:41 PM
Courtesy Access
Karma Power: 36
Default
Sorry my friends I’ve got it know!
I have been creating the following statistics in the following way, please can you have a look at the formula’s to make sure I’m on the correct path.
Cell Statistic & Exactly what I’m
Number Result Entering in Excel
B1 USL =0.005 0.005 (From design)
B2 LSL = -0.005 -0.005 (From design)
B3 STD = 0.001 =STDEVP(B15:B63) (note: B15:B63 is the location of the data)
B4 Mean = 0.001 =AVERAGE(B15:B63)
B5 Min = -0.002 =MIN(B15:B63)
B6 Max = 0.004 =MAX(B15:B63)
B7 Range= 0.006 =MAX(B15:B63)-MIN(B15:B63)
B8 UCL = 0.005 =B4+(3*B3)
B9 LCL = -0.003 =B4-(3*B3)
B10 Cp = 1.25 =(B1-B2)/(6*B3)
B11 Cpu = 3.25 =(B1-B4)/(B3*3)
B12 Cpl = 4.251 =(B4-B2)/(B3*3)
B13 Cpk = 1.08 =MIN(B11:B12)
Old 19th June 2003, 12:43 PM
Courtesy Access
Karma Power: 36
Default
Its in the attachment
Lee01
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 19th June 2003, 01:40 PM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
Wrong
You are using Total Variation estimate (STDEV) to estimate Control Limits, and you are using Total Variation estimate to calculate Cp, Cpk, Cpu, Cpl.
The index calcualted this way is pp, ppk, ppu, ppl
To calculate the Cp, Cpk, and Control Limits use Moving Range or Averages to estimate the variation.
The Total Variation estimate is affected by the variation between samples and within samples, the estimate for control limits is the within sample variation.
Sigma = MR_average / 1.128 (for individual)
or
Sigma = R_average /d2 for (subgroups <>1)
Thank You to Darius for your informative Post and/or Attachment!
Old 19th June 2003, 02:08 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Question Questions...
Lee,
I still don't get it - or maybe I am missing something very obvious!
1.You have posted 55 values, yet the document shows AVERAGE(B15:B63) ie only 48 values.
2. Your computed values are rounded off to 3 decimal digits and the data has 4 decimal digits. There may be some errors due to rounding.
3. I did not try calculting with Excel, but you have so many values above USL (0.005) that Cpk of 1.08 seems unlikely. Then again MIN(3.25,4.251) can't be 1.08 !
4. If by "full sample of points" you mean the entire population, then STDEVP is okay. If not, use STDEV. and yes the index would be Ppk.
Can you please post your original Excel sheet?
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Thanks to Atul Khandekar for your informative Post and/or Attachment!
Old 23rd June 2003, 06:06 AM
Courtesy Access
Karma Power: 36
Default
Okay! Wait a minute.
I understand where your coming from but. . . . .
I'm trying to work out Cpk, & Cp in excel and I have and willl continue to measure the full spopulation (No sample measurement) so I think I'm using the correct Excel calculation.
Is this worng/ correct what should I do? This is being used and has been used for some time in this multinational organisation so are you sure and how will I inform everyone they have been doing it wrong and how they are doing it wrong and how to to do it correct.
Lee01
Reply
Bookmarks
Tags
cpk, excel, ppk
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cpk Formula: Am I using it correctly? Excel .xls Spreadsheet form amna77 Excel .xls Spreadsheet Templates and Tools 14 18th September 2009 10:34 AM
Weibull formula in Excel needs to be verified. vane0326 Excel .xls Spreadsheet Templates and Tools 44 28th April 2009 10:16 AM
Need some help with a formula in Excel Please! Darren Durney Excel .xls Spreadsheet Templates and Tools 11 27th March 2009 07:33 AM
CMM Accuracy - Formula for Excel or a spreadsheet John Bumgardner Excel .xls Spreadsheet Templates and Tools 19 1st July 2008 03:57 AM
Excel formula for Ppk needed Aitch Excel .xls Spreadsheet Templates and Tools 44 1st July 2006 06:12 AM
The time now is 10:46 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
