Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th June 2003, 10:30 AM
Andrews Andrews is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 39
Andrews has less than 100 Karma points so far.
Default Capability: Short Term or Long Term?
I had the opportunity to attend a training programme conducted by one of our customer where the lecturer / facilitator told us something that was in contradiction to what I learnt earlier.
They said that Cp,Cpk is related to short term capability and Pp,Ppk is related to long term capability.What do the forum users feel about it?
Sponsored Links
Old 19th June 2003, 12:56 PM
noboxwine's Avatar
noboxwine noboxwine is offline
Send Martini's !!!!!!!
Registration Date: Feb 2002
Thanks Given to Others: 1
Karma Power: 42
noboxwine is appreciated, and has over 300 Karma points.noboxwine is appreciated, and has over 300 Karma points.noboxwine is appreciated, and has over 300 Karma points.noboxwine is appreciated, and has over 300 Karma points.
Money My Two Cents
You'll typically find, in Automotive:
Cpk= Long term---due to estimated std dev
Ppk= Short term---due to calculated std dev
And, MHO, if the long-term process is stable, this is the way to go. If not a stable process, Cpk is always worthless.
In Software, I have typically seen just the opposite.
I don't see, whether or not it's car parts or CD's, where an estimated sigma (Cpk) is good for any short term capability.
Though, very interested in other opinions as always.
Hope this helps ! Have a day !
Operator Error cannot be the Root Cause. Oh, unless you're a Pilot.
Sponsored Links
Old 19th June 2003, 03:54 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default My Two Cents too
I agree with noboxwine.
Stability is a prerequisite for Process Capability. This can be established using a control chart. A long term study would imply that the process has had a chance to run thorugh all possible cycles and therefore all the common and special causes of variation have been covered. In such cases Cpk is calculated using sigma=Rbar/d2.
Process Performance Ppk involves short span runs of may be 100 consecutive parts. Some of the special causes of variation may not have ocurred at all.
Here are two earlier threads on the same topic:
http://Elsmar.com/Forums/showthread.php?t=1994
http://Elsmar.com/Forums/showthread.php?t=4048
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Old 19th June 2003, 04:16 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
Now I'm confused. I don't have a copy of the AIAG SPC manual here, so I pulled out Ford's CSRs because I remember it being talked about in there. But they contradict themselves! In 4.37 it says...
The choice of the capability index used for initial process studies - Cpk (predictive), or Ppk (historical) – shall be based solely on the nature of the process data collected
But in Table B it says...
After process stability has been demonstrated and capability has been calculated, the most recent point on the control chart and the historical process capability indices (Cpk/Cp) may be used to determine appropriate actions.
It sounds like Ford is confused also. My understanding has always been as stated above - that Cpk was historical and Ppk was short-term.
Old 15th October 2003, 11:55 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
So the answer is???
Old 16th October 2003, 01:19 AM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default Statistics - Blessing and Curse!
Originally Posted by Marc
So the answer is???
ASQ's Body of Knowledge for the Quality Manager certification test describes
Cpk as long-term, stable (Cpk > 1.3 = capable)
Ppk [Potential Process Capability] as short-term, stability undetermined (Ppk > 1.67 = capable) The difference in ratio of being acceptable to be called "capable" is just a fudge factor.
The difference in what is capable ratio is that because the run is short, Ppk does not include the normal variability that will be seen in a full production run.
Now ask me, "What do I really believe?"
I really believe that reliance on such ratios for short runs (Ppk) is really not as informative as pure control charts.
There are links to interesting articles on the topic at
http://www.qualityadvisor.com/librar...ility-menu.htm
Old 4th November 2003, 07:05 AM
QeSmithy QeSmithy is offline
E-Mails Invalid or Rejected
Karma Power: 0
QeSmithy has less than 100 Karma points so far.
Default
I've stumbled across this debate on this forum, which is a coincidence because I was having the same arguement with one of my Quality Engineers.
He also states that his training told him that Cp/Cpk related to Long term, and Pp/Ppk related to short term.
I am a certified Six Sigma Blackbelt, and my training pushed me in the other direction. After a heated debate, I reviewed the training files from the Six Sigma Institute which states the following:
When evaluating process capability…
- A short term study is conducted to see how good a process can be. Data is collected over a short period of time during which the process is influenced only by random causes.Cp, Cpk
- A long term study is conducted to see the process’ actual long-term performance. Data is collected over a long enough period of time such that the process is influenced by both random and non-random causes.Pp, Ppk
- The Process Sigma Level is the z value corresponding to a short term study (centered distribution, when using variable data).
- The Short Term Process Sigma Level can be estimated from a long term study by the adjustment: zST = zLT + 1.5.
- The 1.5 Sigma adjustment accounts for the shift and drift of the short term distribution over time.
- When variable data is used, the capability indices Pp and Ppk are computed:
Cp indicates the process’ potential capability if it were perfectly centered between specification limits.
Cpk takes into account off-centering.
- For a Six Sigma process, Cp = 2.0 and Cpk = 1.5
- When attribute data is used in a long term study, the Long Term Process sigma Level is the z value corresponding to the proportion defective or DPO. The Short Term Process Sigma Level (reported) = zST = zLT + 1.5.
I Hope this helps!
Smithy
Old 4th November 2003, 08:31 AM
Forum Administrator
Karma Power: 90
BIG Smile the eternal debate!
Smithy,
Thanks and Welcome to the Cove.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Interpretation of Short term vs. Long term Capability Studies Chennaiite SPC Monitoring and Statistical Analysis Techniques 3 24th March 2009 09:05 AM
Cp/Cpk vs Pp/Ppk (Short term using population sigma) - Formulas to use? LoudRed Capability, Accuracy and Stability - Process, Machine, etc. 21 24th April 2006 09:13 AM
Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability DJN Capability, Accuracy and Stability - Process, Machine, etc. 25 15th March 2006 01:26 AM
Short and Long term effects of humidity on tooling and gages DE_Perry ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 6th August 2005 12:02 PM
Process Capability - Long-term vs. Short-term Tamashiro SPC Monitoring and Statistical Analysis Techniques 9 19th February 2001 07:34 AM
The time now is 07:00 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
