Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st May 2000, 11:23 PM
dr madhavan dr madhavan is offline
Registration Date: Jan 2000
Karma Power: 41
dr madhavan has less than 100 Karma points so far.
Question Is it necessary to provide specific numbers to the various forms?
Is it necessary to provide specific numbers to the various forms which are used?
Is it not sufficient to identify them with clear description (name)?
Sponsored Links
Old 2nd May 2000, 05:59 AM
eskay eskay is offline
Registration Date: Apr 2000
Karma Power: 39
eskay has less than 100 Karma points so far.
Yin Yang
Dr.Madhavan,
In my opinion, only the name should be sufficient. All you need to have is an unique identification of the form for control purposes.
Any other comments??
Kannan
Sponsored Links
Old 2nd May 2000, 08:28 AM
Jim Biz's Avatar
Jim Biz Jim Biz is offline
Registration Date: Mar 2000
Karma Power: 51
Jim Biz is appreciated, and has over 100 Karma points.Jim Biz is appreciated, and has over 100 Karma points.
Names or titles are unique identification --- but how would you then identify changes to the documents -- I would think you need to also have them identified by date or a revision level to ensure the document is current.
Old 2nd May 2000, 10:20 AM
Tom Goetzinger Tom Goetzinger is offline
An Early Cover
Registration Date: Mar 1999
Karma Power: 0
Tom Goetzinger has less than 100 Karma points so far.
You have to use what works for you. Many companies find that assigning a number to the form makes it clearer. We relate form numbers to elements, but that is only because it works for us; there is no need for the number to mean anything. I found that using a number eliminated any chance of confusion when a form was discussed or used.
Consider your environment and go from there. If a unique form name will serve your purpose, and you are confident that using a form name will remain workable for you as your system develop, do it.
Old 2nd May 2000, 12:22 PM
Karma Power: 41
Yes. We have provided issue / revision status to these forms. Moreover, a Master List shows the current status of all the forms.
Old 2nd May 2000, 02:45 PM
JParrish
Unregistered Guest
Posts: n/a
I like the suggestion Tom made. Naming the forms against certain elements is something that I have started seeing more recently, and wish I would have done the same. It makes everything much more organized and meaningful. We currently give our forms identification that can be a combo of numbers and letters (ie. Quality Change form being - "Qualchg") This suits us, making it easy to find a form by it's id number.
Old 2nd May 2000, 04:35 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
All you have to do is identify them in some way. With smaller companies all the ID you need is the name of the form.
If you look at www.qs9000.com/pdf_files/Doc_Matrix.pdf you will see a document matrix for a small company. None of the procedures, forms, etc. have any identifier other than the disk file name. You could just use the name of the form as several clients have done. Companies turn to numbers and such as their size grows. If you have 5000 people you're gonna have a lot of different forms and procedures - a name simply will not do.
I recomment a letter prefix, number base and 'clarifier' (form, procedure, policy, whatever) suffix such as QA-1234-F (Quality Assurance form 1234) and where hte form is linked to the reference procedure. Let's say QA-1234-P has 3 associated forms - they will be QA-1234-F1, QA-1234-F2 and QA-1234-F3. I prefer the letter prefix so that you don't have to remember a number. If you see PUR you pretty well know its a document 'owned' by purchasing.
Keep it simple and keep it as self evident as possible. I prsonally recommend that a company NOT link procedures to sections of ISO9001 or any other standard. Do what's right for your company. As many companys are beginning to realize, as ISO9001 evolves their link to the old 20 elements means nothing. Nada.
My 3 cents...
[This message has been edited by Marc Smith (edited 02 May 2000).]
Old 3rd May 2000, 09:34 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
I agree what ever works...my personal favorite is link to the requirement .... typically the procedure that calls out its use......
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Controlling filled out "forms" (eg Operator job specific work instructions) toucan Documentation Control Systems, Procedures, Forms and Templates 3 30th May 2008 03:06 PM
Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms skiman Documentation Control Systems, Procedures, Forms and Templates 7 13th April 2006 11:43 AM
Documenting forms, procedures or work instructions - Serial numbers? edwardkwan Documentation Control Systems, Procedures, Forms and Templates 1 31st March 2006 06:05 AM
Changing Revision Numbers - Quality Manual and Forms paula ISO 10013 - Quality Management System (QMS) Manuals 9 30th August 2002 05:11 PM
PPAP Applicability - 10,000 Part Numbers - Control Plans for ALL part numbers? Bryon C Simmons APQP and PPAP 18 15th August 2002 10:24 AM
The time now is 07:54 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
