Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Supplier Quality Assurance and other Supplier Issues
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 2nd May 2000, 05:01 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Question Supplier Audits - Do we have to Rate suppliers?
This thread was imported and the sequence of posts was messed up. I think it started with this:
Originally Posted by clark530
I work for a company that is not ISO certified. They have sent me through Lead Auditor/Lead Assessor training. We want to qualify our suppliers. Purchasing and engineering have taken my Supplier Audit Checklist which uses the 20 Elements and totally changed it. They do not want to rate our suppliers they think. They just want to ask yes or no questions. What can I say to convince them that we should use a rating system for example Satisfactory, Concern, Non Conformance, Not Applicable. Help
Even if it's yes-no questions there has to be numbers! I see no problem with a yes no as long there is an evaluation methodology. What does 5 yes's and 16 no's mean? You have to have some sort of criteria.
Or try a cattle prod while they're sitting on the pot. Stick it under the door - nail their ankle - and they won't even know who did it. But you can smile a lot when you see them as you pass in the hall. They may still not rate the suppliers, but you'll be happy anyway! Cattle prods are always good for a laugh!
Sponsored Links
Old 2nd May 2000, 05:12 PM
Wallybaloo
Unregistered Guest
Posts: n/a
I'm not from a Purchasing environment and may not have the best examples, but consider these:
1. You may need to qualify two suppliers of the same commodity, one as a back-up. Both will rate 'Yes' on the important questions but one will be better than the other. Of course you'll use the best as your primary supplier and only the 'shades of gray' answers will document which one that is.
2. If you're checking ISO registration as one of your qualifiers, the company that's not registered may actually be complying with the standards better, and making a better product, than the registered supplier (is that heresy?). You'll need some explanatory text on that one.
There are probably better examples and it occurs to me that if I had to audit under the constraints facing you, I couldn't expect to provide management with the information they really need.
Sponsored Links
Old 3rd May 2000, 01:33 AM
clark530
Unregistered Guest
Posts: n/a
Old 3rd May 2000, 08:20 AM
Jim Biz's Avatar
Jim Biz Jim Biz is offline
Registration Date: Mar 2000
Karma Power: 51
Jim Biz is appreciated, and has over 100 Karma points.Jim Biz is appreciated, and has over 100 Karma points.
Spin!
Wally - do you get a higher rating for speling? Or do you simply avoid Marc's cattle prod
Old 3rd May 2000, 09:18 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
I Say...
the really savy edit out the "edited by" so it only shows one....:-)
Old 3rd May 2000, 03:25 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Barb,
You're too clever! Still, I don't think it will help me much. Without spell check, I am plain awful!
Marc,
Quite the prankster! Unfortunately (or quite possibly, Fortunately) I share that same affliction. The lighter-side is a good thing.
Wally,
Don't worry about the spelling too much. I can barely read anyway and wouldn't know if your spelling (and Jim's) is good or bad (LOL).
And speaking of good and bad, I will throw this one out to the group...
Nothing new, I suppose, as we have discussed scale systems for rating audit responses/supplier status. Scaling systems are not as useful as people suppose they are (unless a correlation study was done and shows how ratings are connected to response details, I would be skeptical). If one is to use a scaling system, then you should do so understanding this.
As for yes or no, good or bad, descriptions, these are amongst the worst, IMHO. The less descriptive, the higher probability of generating bad data and incorrect conclusions.
Regards,
Kevin
Old 3rd May 2000, 07:18 PM
Marc's Avatar
Karma Power: 605
Listen To Me!
Living seriously is dangerous...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Second part audits - Supplier audits or product audits selena15 Internal Auditing 6 20th November 2008 10:02 AM
Supplier Rating System - Weighting low volume suppliers vs. high volume suppliers fcardillo Supplier Quality Assurance and other Supplier Issues 2 2nd May 2008 08:05 AM
Supplier Monitoring - Do we need to do Supplier Audits? - TS16949 Clause 7.4.3.2 mazura ISO/TS 16949 - International Automotive Quality Systems Standard 7 29th August 2006 09:08 AM
Method to Rate an External Supplier - Kindly assist me sallysun Supplier Quality Assurance and other Supplier Issues 14 10th July 2006 05:33 PM
Supplier Evaluation - Evaluating transport suppliers and equipment suppliers saberfazer Supplier Quality Assurance and other Supplier Issues 2 27th April 2000 03:38 PM
The time now is 12:49 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
