The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 24th July 2003, 09:10 AM
Bob_M's Avatar
Bob_M Bob_M is offline
Metal Bob
Registration Date: Oct 2002
Thanks Given to Others: 1
Karma Power: 78
Bob_M is appreciated, and has over 400 Karma points.Bob_M is appreciated, and has over 400 Karma points.Bob_M is appreciated, and has over 400 Karma points.Bob_M is appreciated, and has over 400 Karma points.Bob_M is appreciated, and has over 400 Karma points.
Question Tolerance of Shop Grade Plus Size Pins?
Alright I was shown the basics on how to perform certain in-house calibrations/verifications when I took over my job...
We measure/verify our pin gage set (rarely used) in-house with a Digital Micrometer (flat/flat) 0.00005" resolution.
What SHOULD the tolerance be for shop grade plus size pins (generic brand)?
I'm getting numbers similar to last year's results (previous QA mgr verified them), but I don't know what the tolerance SHOULD be. None have been over 0.00050 beyond their stated sizes yet...
We have two sets:
.061 - .250
.251 - .500
We/I currently verify them annually, is anyone waiting longer?
What exactly am I signing for here? Where's the packing list? PO? Customer Requirements? - Want to play some Xbox360 on Live?
Sponsored Links
Old 24th July 2003, 09:35 AM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 28
Karma Power: 230
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by Bob_M
We have two sets:
.061 - .250
.251 - .500
I'm not an expert on this, but I have never had a set of + gage pins that were more than + .0002". If they are .0005" over I'd be suspect of them -- maybe there is rust or contamination on them?
How specific does your measurement need to be ?
Cal interval should take into consideration their usage level, previous cal history, and mfr. recommendations. For pins we use often we do them every 3 months, of less often used pins we go annually, but you gotta watch for rust/corrosion.
We have some really good cal experts on the Cove who may be able to answer better.
Mike S. ("Gun Nut")
And they ask me why I drink....
Sponsored Links
Old 24th July 2003, 10:41 AM
Jimmy Olson Jimmy Olson is offline
E-Mails Invalid or Rejected by Recipient System
Registration Date: Jul 2002
Karma Power: 0
Jimmy Olson is appreciated, and has over 200 Karma points.Jimmy Olson is appreciated, and has over 200 Karma points.Jimmy Olson is appreciated, and has over 200 Karma points.
Most likely the gages you have are class ZZ, in which case the tolerance is 0.0002. If you are running into gages that are 0.0005 I would recomend cleaning them and remeasuring.
If 0.0005 is acceptable for what you are using them for then you could special cal them at that tolerance as long as you state that on the cert.
Old 24th July 2003, 11:05 AM
Bob_M's Avatar
Metal Bob
Karma Power: 78
In Reply to Parent Post by Richard Olson
At the moment we're rarely using them (that I know of). I think our die maintainance uses them more often than production.
We have no current products with tolerances beyond 3 places, and the majority of our "manufactured" holes are in thin sheet metal at right around the nominal sizes. Larger holes, even using a caliper are within spec for all current parts. (Smaller Punched holes for our parts are not typcially critical dimensions).
I think we just have the pin as "just in case" or to help verify a hole size during setup...
Most of what i'm reading is between +.00000 and +.00025 with a few as high as .00040.
At the moment its not a major concern...
Should it be? Or should I spend more time on the pins when we actually start using them on a regular basis?
Old 24th July 2003, 11:45 AM
An Early 'Cover'
Karma Power: 230
If a pin .0004" oversize is still okay for the accuracy you need, that's fine, just state this in the cal paperwork.
You might also consider, if you rarely use them, to save you lots of work, make them "calibrate before each use". Teach the users how to calibrate them when they use them. If the users will follow instructions, this can make your cal workload much lighter so you can concentrate on value-added work.
Mike S. ("Gun Nut")
Old 24th July 2003, 12:37 PM
Bob_M's Avatar
Metal Bob
Karma Power: 78
In Reply to Parent Post by Mike S.
Like I said we barely use the pins and our tolerances are not very tight, so I assume .0004 is OK for NOW.
The calibrate before use not going to happen right now.
Old 24th July 2003, 12:44 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 472
Karma Power: 280
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
same business
Bob,
You and I are in the same business. I have a full set of gages and I don't calibrate them in the classic sense, we put a micrometer with 4 place resolution on them before each use. We, too, do not use them very frequently, we use our calipers more often. They do get a bit of use when we run a part with pressed in hardware, since those tolerances are usually +.003/.000 (and can give you a real headache if you are out of tolerance...LOL).
Just another way to skin the cat....in other words....if they are not used...why check them????
Can they be marked "for reference only" and removed from the system?
CarolX
CarolX
Theater is life, film is art, and television is furniture.
Old 24th July 2003, 01:35 PM
Bob_M's Avatar
Metal Bob
Karma Power: 78
In Reply to Parent Post by CarolX
Bob,
CarolX
At the moment I'm keeping them in the calibration loop so they can be used without on the spot calibration. Switching to operator-based calibration is not practical at the moment. At times I barely know how to calibrate certain things. I'm not about to try to teach others how to calibrate. The only exception might be the tool maintenance guy.
Since its only a few hours per year "wasted" its not a big deal yet... I was more worried about what the tolerance should be. *shrug*
So much to learn, too little time, too little money...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Addressing Lots that were measured with Out of Tolerance Gage Pins Beth Workman Nonconformance and Corrective Action 5 24th August 2010 06:36 PM
Hospital Grade and Medical Grade power cord differences? luloo117117 Hospitals, Clinics & other Health Care Providers - Best Practices and ISO 9001 2 5th March 2009 08:18 AM
Spur Gear DOP (Dimension Over Pins) Measurement - 2 or 3 Pins? ScottyWM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6 8th July 2008 06:07 PM
Circularity tolerance of 0.25mm - The correct Go/NoGo gauge size r1daveg Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6 14th May 2007 08:51 PM
Sample Size and Frequency - In-process monitoring in a mass production shop Andrews SPC Monitoring and Statistical Analysis Techniques 2 10th October 2001 09:30 AM
The time now is 05:18 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
