Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th August 2003, 08:30 AM
clcheng's Avatar
clcheng clcheng is offline
Registration Date: Jun 2003
Karma Power: 27
clcheng has less than 100 Karma points so far.
Question T-value used for MSA
I noticed that we can get the t-value from Excel. However, the t-value used in MSA for Bias Example is different from the Excel. Instead, it was tabulated based on Student T Distribution Table using proportionate method coz it's not an interger value.
If the degree of freedom is an integer, t-value obtained from Excel and Student T Distribution Table are the same. However if the df is in decimal, the t-value from Excel is different from table (proportionate method).
Which one is the correct t-value to use for Bias study???
Anyone willing to help me?
Sponsored Links
Old 8th August 2003, 10:49 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
clcheng,
I don't think there is a function in Excel that will give you the t-value for 'decimal' DF. You can always use the same math in Excel that you used for calculating t from tables. For DF=10.8, get t for 10 and 11, then interpolate.
Hope this helps... and welcome to the Cove!
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Sponsored Links
Old 1st September 2003, 09:40 AM
Forum Administrator
Karma Power: 90
Read This!
The latest addition to the AIAG MSA FAQ, answers this exact question:
Q: I can't determine how to calculate the significant t value (two-tailed) in Table 3 on page 88 (value shown as 2.206) and Table 4 on page 90 (value shown as 1.993).
Ans:...
For Table 3: Given that the df = 10.8, look in a t-table in a standard statistical reference book. Look for the value in the t-table for df=10 and df=11, in the t-sub-0.975 column (this column represents the two-sided values for 95% confidence). The value at 10 df = 2.2281 and the value for 11 df = 2.2010. You must interpolate between these values to get the answer for this problem.
Take the difference between 2.2281 and 2.2010. This equals 0.0271. Since the df we are after is 10.8, we need to interpolate by either adding 20% of this value to the 2.2010, or by subtracting 80% of this from 2.2281. 20% of .0271 = 0.00542; adding that to the df for 11 = 2.2010 + .00542 = 2.206, rounded off to 3 places as shown in MSA3. Or you may find 80% of .0271 = .02168. Subtracting that from the df for 10 = 2.2281 - .02168 = 2.206, the same value we found using the alternate method.
Old 28th April 2005, 11:11 PM
Zunaidy Zunaidy is offline
Registration Date: Apr 2005
Karma Power: 19
Zunaidy has less than 100 Karma points so far.
Default significant t value (2-tailed)
there is a function in EXCEL namely TINV(x,y)
x = you just input the default value of 0.05
y = it is the degree of freedom. for the value in table page 90, refer to Appendix C d2 table page 195, look at g=20 and m=5. you will have y=72.7
the result of TINV(0.05,72.7) equals to 1.993
i had compared to the table 3 page 88, it has the correct value.
i'm just using excel to compute bias study & linearity study.
Old 5th May 2005, 04:34 AM
Forum Administrator
Karma Power: 90
Default
A word of caution: In TINV, if degrees_freedom is not an integer, it is truncated. So if you use 72.1,72.2...72.9 Excel returns the same value as TINV(0.05,72).
In this case (I think you are refering to Table 4, page 90),
TINV(0.05,72)= 1.99346231966047 and
TINV(0.05,73)= 1.99299847736256,
They are very close, so interpolated value for 72.7 will be correct (1.993) upto 3 decimal places. You may run into trouble with lower value of DF.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
MSA Excel .xls worksheet that includes GR&R, Bias, Linearity, etc. HDR Excel .xls Spreadsheet Templates and Tools 10 19th May 2006 10:31 AM
Bias - Upper and Lower control Limit - Bias Study page 88 of the MSA 3rd Edition Marie_2007 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 6th October 2005 06:17 AM
MSA Tools - Excel templates for doing the Linearity & Bias, & Stability Studies Courier Excel .xls Spreadsheet Templates and Tools 6 23rd October 2004 08:07 AM
Linearity of Bias in MSA - Why is it important? zamo Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 26th July 2001 11:39 AM
What is the difference between Bias and Accuracy in MSA? Fanjun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 2nd February 1999 12:14 PM
The time now is 02:02 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
