Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Definitions, Acronyms, Abbreviations and Interpretations
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th August 2003, 07:31 AM
Stevenli's Avatar
Stevenli Stevenli is offline
E-Mails Invalid or Rejected
Registration Date: May 2003
Karma Power: 0
Stevenli has less than 100 Karma points so far.
Question Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of
Dear all,
how to understand predictive maintenance in TS2 7.5.1? what's the difference with preventive maintenance? and the most important is how to implement it?
Thank you very much
steven
Sponsored Links
Old 18th August 2003, 07:58 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
An old post for starters:
Posted by Roger Eastin on Monday, 27 October 1997, at 5:16 p.m., in response to Predictive maintenance methods, posted by Felix cruz on Tuesday, 21 October 1997, at 3:06 p.m.
Predictive maintenance methods mentioned in the QS9 standard are identified by the type of equipment you are operating. If you have machinery that uses items such as gear boxes, then you should consider having vibration analysis done on them (if they are considered key manufacturing equipment). Here the analysis would detect gear wear or possible fractures of the gears. If you have equipment that uses control boards which contain electronic circuits, then you need to look at IR testing of the circuits. This analysis would detect "hot spots" on the circuit which may mean that a component is beginning to break down. If the equipment you are running uses lubricating fluids such as oil, then you would look at using a lab to do fluid analysis. Here you would look for oil breakdown or contamination levels. If your equipment uses perishable tooling such as drill or milling bits, you would set up a program to measure tool wear to anticipate failure. For the first three methods, outside companies can do this. You could probably do this last one. (You could even track MTBF of these parts in order to improve wear by using different vendors, different coatings of bits,etc.)
Thanks to Marc for your informative Post and/or Attachment!
Sponsored Links
Old 18th August 2003, 09:27 AM
energy
Unregistered Guest
Posts: n/a
Read This! Ts2?
Originally Posted by Stevenli
Dear all,
Thank you very much
steven
Steven,
"Predictive" seems, to me, another term for "Preventive". If you have a Preventive Maintenance "Process", I wouldn't sweat it. Another standard making its presence known by changing the accepted terminolgy?
Old 18th August 2003, 10:20 AM
Craig H. Craig H. is offline
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
Craig H. is appreciated, and has over 1700 Karma points.
Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.
Default
Originally Posted by energy
Steven,
At the risk of spouting gobbledygook (sp?) here is my take on it.
Predictive maintenance is indeed preventive maintenance, but all preventive maintenance is not predictive. In other words, predictive uses data gathered from the equipment (wear, vibration, etc.) to optimize the interval between instances of a specific maintenance task.
For instance: Why shut down right now to do prev. maint., when predict. maintenance (data gathered) tells us we can go another 100 hours?
Or: It does not matter what the manual says, the oil analysis tells us that the main bearings are toast, and if we don't shut down now, we will be replacing more than bearings... (wham!!! chunka chunka).
JMO
Craig
Old 18th August 2003, 11:06 AM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default
JMO
Craig
I've had companies that have used MTBF and other measures as part of their predictive maintenance program. Does this fit in as well in your definition Craig?
Dave B (the other Dave)
Old 18th August 2003, 11:20 AM
Been around a while
Karma Power: 171
Default
Without a doubt...
Old 18th August 2003, 11:24 AM
energy
Unregistered Guest
Posts: n/a
Thumbs up I buy that
Craig
Let's take my car as an example. The manufacturer requires that I change the oil every 3K miles. Should I analyze the oil and based on the results, extend the intervals an extra 1 or 2 K miles? Do I know more than the equipment manufacturer? And, do I spend big bucks on analysis vs. following the Manufacturer's recommendations. I don't know. If the Customer requires it, charge them more per unit?
Old 18th August 2003, 12:00 PM
db's Avatar
db db is offline
Where's the shall?
Karma Power: 129
Default
My thinking:
If you change your oil, based on the manufacturer's requirements, then it would be preventive
If you change your oil, based on the analsis of the oil then it would be predictive.
The question is should we really worry about the difference?
Reply
Bookmarks
Tags
definition, predictive maintenance, preventive maintenance, ts 16949
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? deminika ISO/TS 16949 - International Automotive Quality Systems Standard 8 24th October 2008 01:28 PM
Predictive maintenance vs Preventive maintenance Michiel ISO/TS 16949 - International Automotive Quality Systems Standard 3 13th February 2007 11:04 AM
Preventive Maintenance vs. Predictive Maintenance - Distinction between darkafar Definitions, Acronyms, Abbreviations and Interpretations 20 22nd November 2006 01:21 PM
Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Rosana Definitions, Acronyms, Abbreviations and Interpretations 11 18th November 2006 04:28 PM
QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance Frank45 QS-9000 - American Automotive Manufacturers Standard 1 23rd September 1999 12:00 PM
The time now is 09:47 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
