Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > FMEA and Control Plans
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 3rd March 1999, 08:21 AM
BILL MAYNARD
Unregistered Guest
Posts: n/a
Please Help! Mold Making Control Plans
I have implemented control plans for our mold making area. Recently hired a project manger who is in disagreement. he says it is not necessary. Your comments please.
Bill
Sponsored Links
Old 4th March 1999, 01:12 AM
Christian Lupo
Unregistered Guest
Posts: n/a
Default
Bill-
Could use a little more information:
1) Are you selling the molds to customers?
2) Are these molds used in making your product?
3) Is this for an automotive manufacturer?
4) Are these "sand mold" such as the ones used in foundries?
My first thought is that it should be part of the FMEA and subsequently part of the control plan.
Sponsored Links
Old 5th June 2006, 12:02 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default Re: Mold Making Control Plans
This is an 'oldie' that was never followed through on. Any contemporary comments or discussion from mold makers with respect to Mold Making Control Plans?
Old 5th June 2006, 10:18 AM
Ederie Ederie is offline
E-Mails Invalid or Rejected
Registration Date: Nov 2005
Thanks Given to Others: 2
Karma Power: 0
Ederie has less than 100 Karma points so far.
I spent years checking mold halves before they were put together, to make sure they would not crash when put in the press.
Each mold was different as far as the building and modifying, so we would use the finished part as our acceptance criteria.
Sometimes the molds were built to be way different than the part, so when the part would cool it would come into specification.
(inward/outward bow, flatness, shrink, etc.)
The only way to know if the build was successful would be to run samples.
We relied a lot on the experience of the engineers and toolmakers, definitely not an exact science.
Hope it helps,
Ed
Old 5th June 2006, 04:16 PM
barbt barbt is offline
$ Contributor
Registration Date: Dec 2001
Thanks Given to Others: 3
Karma Power: 39
barbt is appreciated, and has over 200 Karma points.barbt is appreciated, and has over 200 Karma points.barbt is appreciated, and has over 200 Karma points.
Hope it helps,
Ed
In addition to Ed's comment, we use in-process inspection of critical inserts to verify that the die is being built to spec. Primarily, we control the machines and the processes involved, and inspect as necessary. As Ed said, we don't really know if it was truly sucessful until we run samples. We do have a generic control plan which is used throughout the build process.
barbt
Old 5th June 2006, 11:05 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Originally Posted by barbt
In addition to Ed's comment, we use in-process inspection of critical inserts to verify that the die is being built to spec. Primarily, we control the machines and the processes involved, and inspect as necessary. As Ed said, we don't really know if it was truly sucessful until we run samples. We do have a generic control plan which is used throughout the build process. barbt
Ah, yes, the good old "measure the steel" or "measure the part" debate.
My life in high pressure die casting was full of such heated debates. Some wanted to 100% lay out the mold steel before it ran, others said wait and measure a part.
There were all kinds of bizarre shrink and distortion things going on, where we had to go back and butcher (if you were from the mold shop) or fix (if you were from the foundry) the mold.
I suspect plastic is the same?
Old 31st May 2007, 04:55 AM
joansun joansun is offline
Registration Date: May 2007
Karma Power: 11
joansun has less than 100 Karma points so far.
Send a message via MSN to joansun Send a message via Skype™ to joansun
It is a pity i am in a plastic mold industry but i just have little knownlege about mold, i must try my harder
Old 31st May 2007, 05:32 AM
harry harry is offline
Registration Date: Sep 2005
Thanks Given to Others: 571
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Welcome Joan. I like your attitude and the three post you dug-up from somewhere. It shows that you bothered to search. This positive attitude will take you somewhere, some days.
Enjoy yourself and enjoy learning at the cove.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Can a non-medical device manufacturer (mold making) be certified to ISO 13485? jheinzen ISO 13485 - Medical Devices - Quality Management Systems 10 21st April 2009 11:55 AM
Mold Material Standard - Material for making molds supporting medical devices Ajit Basrur ISO 13485 - Medical Devices - Quality Management Systems 10 14th September 2008 06:43 AM
Control Plans - Intending to transfer our control plans to electronic format Paul Homer Documentation Control Systems, Procedures, Forms and Templates 7 20th September 2000 04:56 AM
Mold Making Area Mangement Dis-agreement BILL MAYNARD QS-9000 - American Automotive Manufacturers Standard 8 10th May 1999 08:56 AM
Control Plans - A few control plans that are generic enough to represent the facility Steven Sulkin FMEA and Control Plans 1 18th August 1998 01:15 AM
The time now is 04:18 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
