Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Preventive Action and Continuous Improvement
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 24th November 1998, 10:19 AM
Johan Gahnstrom
Unregistered Guest
Posts: n/a
Lightbulb Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion
We are a little stuck in our work with iso 9001 concerning 4.14. All help is greatfully accepted.
Sponsored Links
Old 24th November 1998, 12:30 PM
Leslie Garon
Unregistered Guest
Posts: n/a
Default
What exactly are you stuck on?
do you have any kind of corrective or preventive action system?
How are problems reported and fixed? How about what you do after finding and dispositioning nonconforming product? is there a next step researching a cause? investigating/tracking how often the problem occurs or if it reoccurs, similiar problems in the same place?
Do you have a supplier corrective action system?
I'd love to help, but help me out with a few more details.
Sponsored Links
Old 25th November 1998, 01:21 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Johan,
I wrote something about a week ago in the QS9000 forum under the topic of Continuous Improvement Techniques that may help you out. I am assuming that you are having difficulty understanding the element and not having difficulty deploying CA & PA. Give that a look for greater detail and for a crude case example. Otherwise, here is a thought or two.
Corrective Action: Actions taken to eliminate the root cause of an existing nonconformance and to prevent its reoccurrence.
Preventive Action: Actions taken to eliminate a 'potential root cause' to a potential problem that has not occurred.
The element (4.14) requires that you identify areas for both within your organization. The CA portion deals with items such as customer complaints received, nonconformances uncovered as part of internal quality audits, or received incoming materials not meeting specifications for example. These problems exist in the here and now and require corrective action to prevent their reoccurrence. What do you do to correct the issues and how do you document what you did? Did it work (close the loop)? Do you review this as part of Management Review?
Preventive Action is a more difficult idea to grasp for most (maybe because we tend to put out fires rather than prevent them) and can be accomplished in various ways. I like to think of it this way. If a process or system is in a state of statistical control, does a problem exist? Sometimes but not always. There is natural variation in any process or system, but their output may not meet our desired expectations. A process not meeting our expectations may need refining, bu not necessarily correcting. We often think something 'must' be wrong when we don't get the results we hoped for. There is a significant difference in a process not meeting expectations and a process not producing to specification. This misunderstanding of system output usually leads to a landslide of issuing Corrective Action for every problem encountered. Does your organization make defective products occasionally? Mine does. Should I create a Corrective Action Report for each defective product especially if some level of defects is to be expected (the system will never produce zero defects)? No. Doing so would bog down the CA process and creates another set of problems (missing CA reports, CA reports not filled correctly, duplicate CAR for the same problem). Not all problems are Corrective Action opportunities. Some are Preventive Action opportunities. This example is more typical of a Continuous Improvement process with Preventive Action ties. Give thought to which situation you have and take actions commensurate with risks encountered. I hope this helped.
Old 25th November 1998, 10:31 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Kevin,
You have covered the aspects very well. I generally use this when describing the difference between CA and PA.
Corrective Action: Putting out a house fire after it has started.
Preventive Action: Observing conditions that may start a house fire and removing them from the system.
Regards,
Don
Old 26th November 1998, 01:03 AM
Karma Power: 94
Default
Don,
Better said with your few words.
Old 26th November 1998, 01:06 AM
Leslie Garon
Unregistered Guest
Posts: n/a
Default
I've come to explaine the difference this way:
Corrective Action: Resolving an actual cause that exists in direct relation to the problem.
Preventive Action: Resolving potential causes that exist as a symptom of the problem.
With corrective action the cause is known and addressed directly, with preventive action only the potential is known, so you address somthing that could occur rather than that which is occuring.
Old 11th December 1998, 10:44 AM
RRamamurthy
Unregistered Guest
Posts: n/a
Default
I would agree with what Leslie said. Taking it further, I would put it thus:
Putting out the fire in the house is action on disposal of non-conformity.
Ensuring that safety systems are installed in the house such that the house does not catch fire in future is Corrective action.
Ensuring that the barn or the car or the office does not catch fire like the house did, and taking suitable steps for that is Preventive action. Ensuring that flooding or electrocution or such hazards do not take place in the hose even though they have not occured, is Preventive action.
Ram
Bangalore, India
Old 31st December 1998, 09:23 AM
John LeBlanc
Unregistered Guest
Posts: n/a
Default Corrective & Preventive
This is my first posting, as I just "stumbled" upon your site this week. Knowing that you probably have covered this in the past, I am looking for help in drawing the distinction between corrective action and preventive action. Our organization (engineering in the telephony industry) uses process documents and thus has flow charts within each of our process documents. We have just been advised that we need to insert a (new) Corrective & Preventive section into each of our processes.I want to take the approach that tells them to look at the flow chart. What can go wrong? What do you do to "fix" it when it does? (Corrective) Once you have "fixed" it, what measures do you take to stop it from happening again? (Preventive)
Does this make sense? Is it consistent with the ISO9000 standard? (We are registered to 9001) Is it too simple an approach?
Thanks.
Reply
Bookmarks
Tags
capa, corrective action, preventive action
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
High Level CAPA (Corrective Action Preventive Action) SOP Example Needed brecksnowshoer Nonconformance and Corrective Action 6 31st October 2009 10:45 PM
Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA) kedarg6500 Preventive Action and Continuous Improvement 18 17th November 2008 08:30 AM
CAPA (Corrective Action Preventive Action) example to provide training wanted class08820 Nonconformance and Corrective Action 7 1st October 2008 10:54 AM
CAPA (corrective action preventive action) Effectiveness - Medical Device Industry jampot Nonconformance and Corrective Action 3 26th February 2006 04:22 PM
Audit Program and CAPA (Corrective Action - Preventive Action) Effectiveness e006823 ISO 9001 - Quality Management Systems Standard 4 22nd July 2004 02:51 PM
The time now is 11:58 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
