Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th December 2000, 02:39 PM
Proud Liberal's Avatar
Proud Liberal Proud Liberal is offline
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 41
Proud Liberal has less than 100 Karma points so far.
Look! Receiving Inspection: C of C for resins
Having come from an automotive environment, I have been used to getting Certificates of Compliance that meet the following:
1. Printed on company letterhead
2. Complete identification of material
(including lot number, date of mfg)
3. List of tests/inspections performed
4. Standards used is testing
(i.e. ASTM)
5. Tolerances
6. Actual test/inspection results
7. Person certifying results
a) signature
b) printed/typed name
c) printed/typed title
I am now working in a plastic extrusion house that is attempting ISO cerification. Per § 4.10.2.1: "The supplier shall ensure ...... until it has been inspected or otherwise verified as conforming to specified requirements." I thought this would be easy to comply with by simply requiring C of C's with each resin shipment.
Not all of my suppliers are willing and/or capable of providing what I consider an acceptable certification. My real concern goes beyond an ISO compliance. How can I protect my customers from an interruption of deliveries if I inadvertantly accept material as good based on a letter of certification without test results only to find that the resin won't process at the time of manufacture.
Am I overcomplicating this? Is there an easier solution? Based on our size and volume of work, I cannot justify setting up an internal lab.
Any advise would be greatly appreciated.
Sponsored Links
Old 7th December 2000, 11:30 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
A CofC (Certificate of Conformance) typically does not have, by definition, data. It;s just a piece of paper saying "We swear this is good stuff."
What you are used to getting with data is really more than a basic CofC.
You have to judge risk. If you're getting data your rish should be low - so you might want to 'ship to stock' their material. No data? Then you have to determine what you consider acceptable as a check on your end. Part of your determination should include the effect of accepting and using bad material.
Bottom line - you do a basic risk analysis. In the QS world this is supposed to be addressed in the Process FMEA - Actually it's the first step of the PFMEA.
Sponsored Links
Old 8th December 2000, 12:13 PM
CarolX's Avatar
CarolX CarolX is offline
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Zeno,
What Mark said is correct, you have been receiving test reports on your material, not certificate of compliance.
Talk to your suppliers and see what they can provide. Perhaps they, too, do not have the facilities to run an internal lab and are relying on their supplier's test data (which could then be forwarded to you with the shipments).
Of course, what you do needs to be based in reality. Are you making rocket parts, or lego's?
Old 11th December 2000, 10:09 PM
freeda
Unregistered Guest
Posts: n/a
BIG Smile
What you are use to getting is a C of A (certificate of analysis).
We do both plastic injection molding and metal machining. I receive a material certification detailing the chemical composition for metals (material certification or certificate of analysis), but only a C of C (certificate of compliance) for plastics. I compare what we ordered to what they say they send us and that's that. That is our receiving inspection for plastics, since we do not have a chemical lab. The way we justified this "simple" inspection is because in 26 years we have had no cases of having bad resin. It is written in our procedure that the C of C will be sufficient. We do have a few instances where our customer requires actual test results on the raw resin to be sent to them (usually at PPAP stage), so we deal with those on a one on one basis.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Critical Characteristics in Incoming (Receiving) Inspection - Inspection Levels luciano Inspection and Test, Sampling and Related Topics 14 20th October 2009 01:54 AM
Receiving Inspection Procedure - Visual inspection defined little__cee Inspection and Test, Sampling and Related Topics 12 9th October 2009 12:25 PM
Should we do Incoming Inspection (Receiving Inspection)? emmasj Inspection and Test, Sampling and Related Topics 14 11th January 2007 04:42 PM
Process Control Plan and Inspection Plans - Receiving and final inspection required? krishkaar Inspection and Test, Sampling and Related Topics 8 3rd November 2004 07:46 AM
Receiving Inspection Instructions for PCB's sas1965 Inspection and Test, Sampling and Related Topics 3 28th September 2004 01:50 PM
The time now is 02:43 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
