18th September 2003, 09:44 AM
Registration Date: Jun 2003
Karma Power: 27 Karma: 10
How do I calculate Cpk with a single Control Limit?
Is it possible to come up with a CPK for a part with a single control limit. We take readings on the part and the minimum reading allowed (the single control limit) is 25, however it can be above 25, just not below 25. Therefore we have readings anywhere from 25 to 55. How would I go about calculating a CPK with the single Control Limit of 25? I'm sure this is very simple for most everyone, but I'm very new to the Quality Assurance program. Any help would be greatly appreciated. Thank you all.
Bob Salmans
18th September 2003, 10:11 AM
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Welcome Bob in KY!
I think you are confusing between Control Limit and Specification Limit. In this case 25 appears to be the Lower Spec Limit. (Is the upper spec 55? If yes, then you clearly have two sided specs.)
This topic has been discussed before:
Calculating Cpk on a single sided tolerance
CP and CPK for product w/ only LSL
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
18th September 2003, 10:22 AM
Cpl...thank you!
Thank you Atul Khandekar, I now see that I cannot get a Cpk and must use a Cpl. Thank you again.
Bob Salmans
18th September 2003, 11:02 AM
Registration Date: May 2003
Karma Power: 28 Karma: 72
Hi Bob,
I have several parts in which there is only one spec limit. CPK is calculated by "x(bar) - LSL / 3s".
Good luck,
-Fox
18th September 2003, 11:10 AM
cpk
Cleverfox, pardon me for being ignorant on the subject but what is the "s" in the "3s", of x(bar) - LSL / 3s. Thanks.
Bob Salmans
18th September 2003, 11:19 AM
would the "s" in "3s" be Standard Deviation?
Bob Salmans
18th September 2003, 01:16 PM
Bob,
The "s" is for standard deviation; calculated as s = R(bar)/ d2. The "d2" is a constant and its value is found on a chart in the AIAG SPC reference (or other SPC guides) manual.
-Fox
17th November 2003, 11:57 PM
Registration Date: Nov 2003
Karma Power: 25
Your 25-55 should be the sampling amount,right?.
Actually,it would be stlll OK if over 55. The reason why we have to collect 25 above is that the sampling distribution of X-bar will be approaching to Normal distibution. This is derived from "Law of large number" in statistics.
