23rd September 2003, 02:38 PM
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
Business in a Box
Hi, all.
I just got back from a conference call with a vendor. Have any of you Covers had experience with Business in a Box specifically and Lotus Notes in general? Did it make the QA job harder or easier, and more or less effective?
I would appreciate any input, especially if there is something I should be kicking and screaming about.
Craig
On a lighter note, is Business in a Box anything like Janitor in a Drum?
23rd September 2003, 04:09 PM
VINI, VIDI, DORMIVI
Registration Date: Feb 2002
Thanks Given to Others: 20
Karma Power: 84
Craig,
I used Lotus Notes when it first came out. If they fixed half the problems with the initial release it would be a good software. It's been around for a while now and I've not heard much about it. That's an indication that either it's doing well and no big issues have surfaced,or it's so bad no one wants to admit in buying it!
I'd be afraid that it would be more like the Marvin the Martian's alien in a gumball machine (just add water)!
"What this country needs is more unemployed politicians." Edward Langley
23rd September 2003, 04:28 PM
Courtesy Access
Registration Date: Feb 2003
Karma Power: 66
Originally Posted by Craig H.
Hi, all.
Craig
At a former employer's we used Lotus Notes for our document control system (home grown adaptation). It seemed to work as well and as easily as using Mickeysoft and Novell. Documents were created in MsWord or Excel then routed for approval via and maintained in Lotus Notes.
David D. Hartman
23rd September 2003, 05:50 PM
Been around a while
Karma Power: 171
Thanks, y'all. I hope some more people see this and offer advice, as well. This is going to be a heck of a big change for us, if we decide to do it.
Craig
12th February 2004, 08:06 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
As a quick note, Lotus Notes has significantly changed over the years and from what I've read is quite stable and performs well. If I remember correctly, they also recently included Linux as a supported platform.
13th February 2004, 09:15 AM
When in doubt - THINK!
Thanks Given to Others: 113
Karma Power: 217
My organization uses Lotus Notes and it does appear to meet our needs with minimal hiccups.
The only downside, would be using our QSi software with it. Originally, QSi was for a Lotus Notes platform and while they've changed, those of us still using the release requiring Lotus Notes, well, it makes it difficult for us to send documents via email.
I can send a copy of my QSi docs to other people via email, but if they do not run off of a Lotus Notes platform, they lose all the formatting and have to scroll through yards and yards of meaningless text to get to the good stuff.
That'd be by my one complaint, but it's probably more of a QSi thing than Lotus Notes.
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
13th February 2004, 09:45 AM
Been around a while
Karma Power: 171
RC, They just installed QSI on my box around 4:30 yesterday.
But, ALL of our PCs will be running Notes, so hopefully there will not be any problems. Thanks for the "heads up".
Craig
13th February 2004, 09:54 AM
Karma Power: 217
Craig
But did your organization get the Lotus Notes based version of QSi or the the web-based one?
Best of luck...but if you wish to form a "therapy group", let me know!
It really isn't all that bad...I mean how many times do you anticipate sending documents outside of your system. It does get awkward with Customers, but I tell them that I will courier them a copy of our Quality Manual. If they ask why we can't send an electronic copy, I state "security protocol" as the reason (i.e., can't change a hard copy to say something different whereas the e-copy could be modified). Usually accepted.
~ Roxane ~
