26th September 2003, 03:54 AM
E-Mails Invalid or Rejected
Registration Date: Aug 2003
Karma Power: 0 Karma: 10
How to Calculate Reliability Acceptance Criteria
help!what is the mean of "P0.90=0.95"? I only know it's a acceptance criterion.How to calculate?
thanks!
nancy chen
26th September 2003, 12:32 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
We need to know where this comes from. And, what is it acceptance criteria for?
26th September 2003, 11:11 PM
It is a reliability criteria.
I only know that P0.90=0.95 means a minimum reliability of 95% at 90% confidence.How to use the reliability criteria?
7th March 2004, 03:19 PM
Karma Power: 605
Does this ring a bell with anyone?
30th April 2004, 08:22 PM
Registration Date: Apr 2004
Thanks Given to Others: 13
Karma Power: 50
I will take an attempt.
Area of Engineering:
This falls under the category of estimating reliability at a given confidence interval.
Scenario:
In a real life situations if we perform test for a wear out, we have data like:
Mean time to wearout, Variance of mean time to wearout, sample size, and we may want to know the time we can expect 95% of the units still functioning at 90%confidence.
Calculations:
Assuming this data following a normal distibution. (Wear out period typically follow normal).
The lower 90% confidence limit can be calculated by:
Lower Limit of Mean XL= Mean time to wearout (Xbar)-Z (standard error of mean)
Z=1.282 from table.
(standard error of mean= std.dev of mean time to wearout/squareroot of n)
Now the 95% Lower limit value for reliability is:
X at 95% = XL at 90% -(Z*std.dev of mean time to wearout);Z=1.645 from table.
Applications:
These type of estimations are very useful for setting warranty, setting spares inventory and lifecycle cost estimations.
Useful references:
Reliability Engineering Handbook - Kececioglu Vol 1 & 2.
Regards,
Govind.
Thanks to Govind for your informative Post and/or Attachment!
