10th October 2003, 06:52 PM
Registration Date: Oct 2003
Karma Power: 25 Karma: 10
How do I enter materials into IMDS (International Material Data Sheet)?
I'm trying to enter a spring into the IMDS system. It is made of music wire with a zinc plate. I assume the spring is the component and the the music wire and zinc plate are subcomponents. So how do I enter the basic substances for the music wire and zinc plate? Thanks in advance for any help you can give.
11th October 2003, 08:06 AM
E-Mails Invalid or Rejected
Registration Date: Jan 2003
Karma Power: 0
Edward,
I believe IMDS offers a step by step document that is downloadable. Their web site is: www.mdsystem.com
When I took the training it was free, I am not sure it is the case now.
Hope this helps you some.
Cindy
12th October 2003, 04:04 AM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
There's a condition about the reporting you should explore:
"All the substances and substance groups listed in the List of Declarable Materials in Automobile Manufacturing - Substances in Components and Construction Materials must be recorded with the Initial Sample Test Report VDA - Constituents in Purchased Parts (Material Data Sheet), if they are present in the products, or if they run the risk of being released. Mass limitations i.e. content limitations for individual substances have been specified. If the content level falls below these limitations, it does not have to be declared. These limitations are 0.1g/100g (weight %), unless otherwise indicated."
I'm sure we'd all be interested in what you finally learn.
12th October 2003, 02:22 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
I spent a lot of time going through manufacturers MSDS sheets for a lot of information. I did several of these last year for submission to Visteon. The biggest 'problem' was the time getting all the information. getting the percentages to match and such was a pain the first time, but once I understood what it wanted it wasn't that hard.
I never did copy one of the files to my pc however, so I don't have one to reference.
13th October 2003, 09:58 AM
Registration Date: Sep 1999
Karma Power: 90
I'm trying to enter a spring into the IMDS system. It is made of music wire with a zinc plate. I assume the spring is the component and the the music wire and zinc plate are subcomponents....
Call the help desk. They are extremely helpful and will walk you thru the process.
Sam Goody
13th October 2003, 10:01 AM
Karma Power: 90
Wes, What is this documented located? Each OEM has their own list of reportables but I don't recall seeing this list or ststement.
Sam Goody
13th October 2003, 09:28 PM
Involved - Posts
Registration Date: Aug 2003
Thanks Given to Others: 2
Karma Power: 38
IMDS reporting
We received direction by letter from GM and Delphi on disclosure of materials
several years ago. They both put it on new part prints, referencing a
GM or Delphi engineering spec. If you want more details I can look them
up at the office. Delphi requires IMDS or use of an AIAG form. I believe that
GM wanted IMDS.
I haven't seen this added to QS or TS CSR's, though, if that's what you mean.
Brad
14th October 2003, 08:18 AM
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
GM wanted IMDS.
Brad
Although Delphi "requires" IMDS, they don't follow their own procedure - YET. We still have to submit the "Old" hard copy form (A10949001) because (we've been told) they won't be up to speed until mid '04 at the earliest. Might depend on which plant(s) you supply, though.
GM was excellent (sorry, different thread  ) with the response of acceptance and you can even "see" the approval on the GQTS system. (Doh! Did I just say GM=Excellent???)
The rest of our customers still want the hard copy versions (GMW3059 or their own form).
Bill
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
IMDS (International Material Data System) - OEM Requirements
sunder_syam81 |
RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations |
8 |
26th August 2008 12:39 AM |
PPAP and the IMDS (International Material Data System) - What did I get myself into?
silentrunning |
10 |
25th September 2007 02:32 PM |
IMDS (International Material Data System) Training needed
Jan91168 |
8 |
31st October 2006 05:23 AM |
What's IMDS? International Material Data System (automotive)
Cordon |
11 |
25th July 2006 06:07 AM |
International Material Data System - IMDS
Dave.C |
6 |
9th July 2003 07:48 PM |
