Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th October 2003, 11:54 AM
el_quixiote el_quixiote is offline
Registration Date: May 2003
Karma Power: 27
el_quixiote has less than 100 Karma points so far.
Screw Record Retention - NC for keeping records longer than our defined minimum
Hi. Maybe some one could help me.
We had an qs audit an the auditor found that we have retained our quality records more than the minimum requiered and the auditor is documenting this fact as a non-conformancy.
Is that correct. I've read the qs-9000 4.16 clause and in the last sentence states "This periods are considered as minimum".
So, I think I'm not in a non conformancy situation.
Am I wright?
Sponsored Links
Old 15th October 2003, 12:03 PM
Icy Mountain's Avatar
Icy Mountain Icy Mountain is offline
Sachem
Registration Date: Aug 2003
Thanks Given to Others: 53
Karma Power: 98
Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.Icy Mountain is appreciated, and has over 1700 Karma points.
Default What did you document?
Great name el_quixiote. Quality can be a quixotic struggle. Welcome to the Cove!
For example: you wrote in your procedure that you will keep a record for three years, then throw it away. If you keep the record for four years, you have a non-conformance to your system, even if the standard says keep them two years, as a minimum. Correction: write your procedure to say "keep the record three years (as a minimum), then throw it away.
Did you know that facts remain even when you disregard them?
Sponsored Links
Old 15th October 2003, 12:18 PM
SteelMaiden's Avatar
SteelMaiden SteelMaiden is offline
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
Default
Greetings el_quixiote!
No it is not a nonconformance just because they are kept longer than the minimum retention. The standard states that retention times are minimums. BUT, if keeping the records longer than the minimum (much longer??) starts to create storage problems where you might not be able to access the records or maintain their integrity/legibility then he could write up a nonconformance about your retention periods.
Icy makes a valid point about documenting, even if the standard clearly states that all retention periods shall be considered minimum, if you just make a simple statement saying that all retention times recorded in "such and such document" are considered to be minimum retention times and records will be destroyed, (or whatever) after that time as storage space dictates, they'll never be able to hang you. I don't know what TS says, I was with a QS division and we never had a problem with minimum retention times.
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
Old 15th October 2003, 12:27 PM
howste's Avatar
howste howste is offline
Thaumaturge
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
I've seen this come up before. I think it comes from the fact that the OEMs would prefer to have records destroyed after their required retention periods in order to eliminate any liability.
Example: you are required to maintain records for the life of the part plus one year. In the year after the required retention period, a $$$$$$$ lawsuit comes up against the OEM for some alleged problem. The prosecution lawyers subpeona your records and find that Joe Temporary forgot to do his dimensional checks for a couple of days. They treat this as a smoking gun that the product is defective and they win the case.
BUT, like Icy Mountain said, if you define your retention requirements carefully they shouldn't be able to write it as an nonconformity. Please look at your record retention requirements and make sure that you didn't write them in a way that required you to destroy them after the minimum time.
Old 15th October 2003, 01:16 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
I disagree about liability reason for discarding documents and records. There are just as many documents and records which would defend a liability question. (Unless, of course, the organization is willfully performing processes which may harm or injure others. In which case, why bother to keep ANY records?)
In my experience, well-run organizations want to discard documents because they are obsolete or no longer have a purpose. Records are a special kind of document which are kept for a variety of reasons (government regulation, customer requirement, historic reference, etc.)
An organization needs to make the same kind of decisions about retaining records (hard copy or computer) as it does about retaining inventory or production equipment.
In my most recent organization, our Quality Manual refers to the process for this :
4.2.4 Control of records
Records may be hard copy or electronic. A record is a special document which holds data generated during the course of performing a process. We control a document by maintaining its integrity against loss or alteration during its useful life. We provide access to a record to all interested parties. We may aggregate data from records into reports or summaries. We may analyze the data contained in a record with a view toward modifying or retaining a process.
We have a documented process to determine which controls over identification, storage, protection, retrieval, retention, disposal shall apply to a specific record.
Does this coincide with Cove members reasoning?
Old 15th October 2003, 01:26 PM
howste's Avatar
Thaumaturge
Karma Power: 206
Default
What I stated above I have heard from more than one QS-9000 auditor in exactly the context stated by el_quixiote. I personally feel, like you, that records are more likely to help in court rather than hurt.
Old 15th October 2003, 01:32 PM
mshell's Avatar
mshell mshell is offline
Involved - Posts
Karma Power: 50
mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.
Default
We state in our procedure that we can maintain records longer than the minimum retention period without formal justification and that the purpose for disposition is to free up filing space. As far as the company is concerned, we must keep them for 1 yr. but we could possibly keep them forever if we want.
If the nonconformance was written because of your procedure, then change your procedure and the nonconformance is resolved.
The 1yr is just an example. We do have some that we keep forever!!!
Old 15th October 2003, 01:38 PM
mshell's Avatar
Involved - Posts
Karma Power: 50
Default
This our current QM statement. It directs the auditor to the operational procedure which clearly defines what records we control, responsible party, period, location, doc #, doc name, and disposition.
4.2.4 Control of Records
Records have been established to provide evidence of conformity to requirements and of the effective operation of the quality management system. Controls are established for ensuring that records remain legible, readily identifiable and retrievable.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
What is the Minimum Regulatory Requirement for Record Retention of DHR by Suppliers CharlieB Records and Data - Quality, Legal and Other Evidence 9 11th October 2009 08:10 AM
Defined Records Retention Time Of Customer/Regulatory Requirements pmwong Records and Data - Quality, Legal and Other Evidence 4 7th August 2007 04:55 AM
Is there a minimum retention time for any of the Quality Records? ISO9001 ttwerp65 Records and Data - Quality, Legal and Other Evidence 8 24th January 2007 01:34 AM
Minimum retention or the date of destruction of a record - ISO 9001-2000 Para. 4.2.4 Bob Schiller Records and Data - Quality, Legal and Other Evidence 13 8th January 2007 02:05 PM
Can you define keeping quality records at a minimum of 3 years? Dawn Records and Data - Quality, Legal and Other Evidence 7 27th January 1999 08:39 PM
The time now is 04:03 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
