17th October 2003, 03:06 PM
Registration Date: Oct 2003
Karma Power: 25 Karma: 10
ISO 9001 / ISO 13485 - What is considered a 'documented' procedure?
Has anyone ever run into issues with auditors over what is considered a documented procedure? In my company we have documents titled "procedures" however we also have some documents titled "work instructions" I think ISO regards both as "procedures" and we have had a consultant tell us that the auditor won't argue any difference. Anyone have any insight/comments/suggestions?
17th October 2003, 03:17 PM
QA-LA
Registration Date: Jan 2000
Thanks Given to Others: 5
Karma Power: 71
You are correct they are pretty much the same.
17th October 2003, 04:05 PM
qualitas ad nauseam
Registration Date: Sep 2003
Thanks Given to Others: 3
Karma Power: 79
There are subtle differences, although to the rest of humanity outside the quality field it appears fairly anal. A procedure tells you what to do and who does it, whereas a work instruction tells you how to do something.
When an auditor starts picking on those things, he should get one of those things called "a life".
20th October 2003, 10:47 PM
Registered Visitor
Karma Power: 26 Karma: 15
I do agree with Rob that there are differences between them. Procedures should be written in a general way on what should be done, while working instruction should be more specified to tell the operators how to work on it. For example, we can have a procedure on what we need to do for a plastic molding process, but a working instruction shall be written specifically for those operators who handle the molding machine, step by step, on how to operate the machine.
That's what my understanding.
21st October 2003, 08:46 PM
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
There is no requirement in either the 9001 or 13485 standard that you must call any document by a particular name. You can call it a process instruction, SOP, policy, SWI, requirements document, standard, specification, etc., etc., etc. If it looks like a procedure, acts like a procedure, and functions like a procedure then it meets the requirements for a procedure.
The same goes for quality manual, quality policy, quality objectives etc. You can call them your business manual, vision statement, and key performance indicators if you'd like.
15th August 2004, 07:58 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Is anyone interested in restarting this debate?
