Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 4th November 2003, 07:47 PM
tattva tattva is offline
E-Mails Invalid or Rejected
Registration Date: Apr 2003
Karma Power: 0
tattva has less than 100 Karma points so far.
Default Cpk
Hi all!
Could someone help me with the following:
How much does CPK>1.33 represent in precentage of good pieces? Is there a matrix where I can find these values at Cpk>1; Cpk>1.67; Cpk<1; Cpk=0?
Thanks in advance!
Sponsored Links
Old 4th November 2003, 08:30 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
I've only got a minute before I've got to go, so I'll just get you started...
First, in order for the statistics to be meaningful, you need to have a normal process that is in control. Now, the percentage can actually be different depending on if the distribution is centered or not. A perfectly centered process with Cpk = 1 will have twice as much (theoretical) nonconforming product as one with a Cpk = 1 that is not close to being centered.
What you need to get the percentages is the Z value(s) and a "standard normal" table to look up the results. When you look at the formulas you find that basically Z = 3xCpk.
I'm attaching a standard normal table - hopefully you can figure it out from here. If not I'll be back later...
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Thanks to howste for your informative Post and/or Attachment!
Sponsored Links
Old 5th November 2003, 07:19 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
Here is a very clear article with a table of the results
http://www.symphonytech.com/feature.htm
article Measuring Your Process Capability
Old 5th November 2003, 12:23 PM
howste's Avatar
Thaumaturge
Karma Power: 206
Default
Great link, Howard. I was trying to explain how a watch works, when all Tattva asked for was the time...
Old 5th November 2003, 12:47 PM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
Howard, it's a great link, tanks for the tip
For the ppm to Cpk question, both articles, Capability and Six Sigma look like a check mate (no more can be told).
From Six Sigma article (in Howard's link)
Cpk =0.8406+(29.37-LN(ppm)*2.221)^0.5
or
ppm = EXP(-((Cpk-0.8406)^2-29.37)/2.221)
But keep on mind what Don Wheeler said in te point 8.4 from Advanced Topics in Statistical Process Control, 1995.
"It's impossible to convert a capability ratio into a fraction of nonconforming product without using some probability dsitribution in the convertion... of course
, the traditional assumption is that the data are normally distributed.... in most cases the uncertainty in the fraction nonconforming will be greater than the refinement offered by such convertion"
Old 5th November 2003, 01:26 PM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Originally Posted by tattva
Hi all!
Thanks in advance!
I'm going to step out on a limb and say that Cpk, in and of itself, will not tell you how many good parts you have. Cpk only measures process centering.
Case in point; I have a process that has a Cpk= .8 , Cp = 1.66, Zmin = 2.386, Spec avg = .125, Process avg = .1197
There are zero nonconforming parts. All data entered was within spec.
Using the Z-value would show a "potential" for approx. .85% nonconforming.
When I want to relate percent defective to number of parts I use PPM.
Sam Goody
Old 5th November 2003, 01:41 PM
howste's Avatar
Thaumaturge
Karma Power: 206
Default
The usefulness of statistics comes from measuring samples and then making inferences about the population. My question is (assuming the process is normal and in control), did you measure every part in the population? If not, then I would guess you really do have nonconforming product, you just didn't happen to find it in the samples you took.
Old 5th November 2003, 03:29 PM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
I think that's what I inferred in my response when I said the reaults of the Z-value provided the "potential" nonconformances.
In response to Tattvas' question "can Cpk be related to Nonconformances"? I said no, and I stick wth that.
Sam Goody
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Is Cpk a good measure of capability? There are several shortcomings of Cpk Tim Folkerts Capability, Accuracy and Stability - Process, Machine, etc. 31 12th February 2009 07:39 PM
Quality Control Index - We thought that Cpk or Ppk would be good choices vskiller Capability, Accuracy and Stability - Process, Machine, etc. 6 28th June 2007 12:57 PM
How to compare Cpk and ppm (bad pieces) drebernik Capability, Accuracy and Stability - Process, Machine, etc. 3 9th May 2007 10:46 PM
Can CPK be a good manufacturing processor’s quality objective? darkafar Capability, Accuracy and Stability - Process, Machine, etc. 14 22nd March 2007 12:58 PM
Is it possible to have a process that is too good? Cpk is 14.63 DJN Capability, Accuracy and Stability - Process, Machine, etc. 11 5th May 2005 04:58 AM
The time now is 04:06 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
