Management Review: Separate Procedure or Description in Quality Manual?
I am just curious to find out if most people address Management Review in the Quality Manual (only) or if you have a Management Review procedure? Please post to the poll. Also, if anyone would like to share their procedure please do so.
I never liked having a MR procedure when I was quality manager. I felt it was a waste of time & effort. I typically recommend using a form. It helps to ensure that all of the required inputs, outputs, and topics are covered. I posted an example of one recently in another thread...
I am leaning in the direction of a form as well. I have referenced Management Review in all of the relevant procedures and the quality manual. I do not want to create a procedure if it can be avoided.
I think that I found the form that you referenced. I have modified it just a bit. Let me know what you all think. Will this satisfy the requuirements for Management Review?
We have a procedure for MR. Of course, there is no requirement for a MR procedure, but for us it makes sense to have one. In fact there is no requirement for a MR meeting per se...
We are required to review the organization's quality management system, at planned intervals.
Our Management Review Procedure is an organization-wide document. It is NOT a Work Instruction, but a broadly-written document which allows creativity and THOUGHT by managers in setting or modifying timetables for review of different processes throughout the organization. Similarly, it allows some processes to be reviewed by a single manager and others to include several managers and manager levels to deal with processes which may encompass more than one department.
The key ingredient is flexibility to conform to the needs of our organization as they may be perceived at a particular point in time. (For instance, we do not defer a management review on a "hot" item just because it isn't due for review until next quarter. Similarly, we don't drop everything to review a non-critical process just because the Corrective Action Report hits the manager's desk today.) Many items do not require a committee meeting for action to be determined (modify or let stand) and can be reviewed by one person or several by circulating the folder containing information to the appropriate manager(s).
__________________ "Few minds wear out; more rust out"
Thanks to Wes Bucey for your informative Post and/or Attachment!
Michelle, Have you addressed process performance from 5.6.2c? You may have it covered in the objectives, but it's not clear when the form is blank. It could meet the requirements, depending on what information you put into it.
Of course the real test to see if the form works for you is to try it out. If it's easy to use and reminds you to include all of the "right stuff" then it's great. If it's cumbersome and gets in the way, then tweak it some more or work something else out.
