Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th January 2000, 02:56 PM
chivas industries llc
Unregistered Guest
Posts: n/a
Question When to submit a new PPAP? Colored resin pre-blended to blending it in-house
There is much confusion within our company concerning when certain changes require a new PPAP submission for a current production part. For example, we are switching from receiving our colored resin pre-blended to blending it in-house--using the exact same base resin and colorant our outside compounder was using.
Our APQP manager says we have to re-PPAP and re-do all testing called out by the specs on the assembly drawing, for each component for which we want to blend resin. (i.e. complete level 3 PPAP...) Our engineering manager disagrees, saying that this change should be transparent to our customer.
Under what circumstances, and in what situations, is it required that a subcontractor submit a new PPAP package for a current production part?
Thanks,
Melissa Weiandt
Associate Buyer
Plastics Div.
Sponsored Links
Old 11th January 2000, 09:11 AM
Christian Lupo
Unregistered Guest
Posts: n/a
If you are dealing with an automotive customer you DEFINATLY have to re-ppap, unless you get a waiver from your customer. Always ask your customer if you are not sure if you should re-ppap or not. Just make sure you document waht the customer tells you.
Sponsored Links
Old 11th January 2000, 09:22 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Melissa,
As you already know, PPAP attemps to solidify the process of manufacturing and the control planning you set in place to ensure that all requirements are understood and that the process has the potential to produce these requirements. When the approved process changes, the impact must be determined, and the customer notified as appropriate.
What controls were in place for the original resin/colorant blending? Are they called out in the PPAP documentation? Have they changed? My guess is that your APQP person is probably correct. A change from blending at a source to an internal process (perhaps you are new to this process as well) is fairly significant and will likely have different controls (reference section II of the PPAP manual, 3, 7 and 9 on page 2). With these different controls, items such as the Flow Diagram, Control Plan, and FMEA will all be updated to reflect the change.
I hope this helps.
Regards,
Kevin
Old 13th January 2000, 12:03 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Covering Ass
Melissa, I also suggest you do a search here for PPAP as this is a topic which has been discussed a number of times. It might give you some other ideas. I just did a Search for PPAP (all forums) and about 80 threads came up.
...and re-do all testing...
The extent of specific retest(s) depends upon the specifics of the change. I would discuss you change(s) with the customer QA rep and ask what they feel is appropriate. In the past when i did this stuff I would make up a plan (proposal) and get the customer to approve it prior to proceeding with the plan. I would say "This is the proposed change" and "This is what we believe the change will affect." The plan says: "This is what we plan to do to ensure the changes do not change the product features we believe will be affected.
An example: If you machine steel parts which can rust -> a packaging change could prompt PPAP but validation would probably be limited to corrosion studies (if you previously validated this aspect).
Old 18th April 2006, 01:57 PM
Gilberto Gilberto is offline
Well
Registration Date: Sep 2005
Karma Power: 18
Gilberto has less than 100 Karma points so far.
Send a message via MSN to Gilberto
Default
if duly it will be waked up with its customer is not necessary re-submit.
Old 17th May 2006, 09:18 PM
Salman Salman is offline
Involved in Discussions
Registration Date: Dec 2004
Thanks Given to Others: 3
Karma Power: 21
Salman has less than 100 Karma points so far.
Default
Tell him that even change of your supplier is transperant to the customer, yet it still requires PPAP.
Old 22nd May 2006, 11:19 AM
Murph095's Avatar
Murph095 Murph095 is offline
I make things happen
Registration Date: Nov 2004
Karma Power: 27
Murph095 is appreciated, and has over 200 Karma points.Murph095 is appreciated, and has over 200 Karma points.Murph095 is appreciated, and has over 200 Karma points.
Default
Just ask the supplier SQA if it is required, this will leave no doubt. Better yet, maybe ask that individual if they would be willing to come in and have a meeting decsribing what changes require what actions thus alleviating yourselves from this issue in the future.
Murph
Ran into a chum with a bottle of rum and we wound up drinking all night!
Old 8th June 2006, 08:45 AM
Szacinski Szacinski is offline
Registration Date: Jun 2006
Karma Power: 15
Szacinski has less than 100 Karma points so far.
Default Re: When to submit a new PPAP? Colored resin pre-blended to blending it in-house
My understanding is that any process change should signal a new PPAP.
Only time you do not need to re-new the PPAP is when STA/SQA has said something else.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
PPAP Part Supplied to Multiple Plants - Submit another PPAP or PSW to the new plants? lperry APQP and PPAP 6 4th June 2008 12:15 PM
Bulk Material PPAP (Resin Suppliers) pmwong APQP and PPAP 3 26th April 2008 12:41 PM
PPAP - How do you submit PPAP documentation for multiple routes? QLTYgreenhorn APQP and PPAP 10 8th December 2007 12:44 AM
Process capability for blended fluids? PPAP book section 1.2.2.9.1, page 6 Noelia Capability, Accuracy and Stability - Process, Machine, etc. 6 16th February 2006 05:49 PM
Must a Subcontractor submit PPAP Dawn APQP and PPAP 2 12th April 1999 01:06 PM
The time now is 08:48 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
