Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th January 2000, 05:32 AM
Nikos
Unregistered Guest
Posts: n/a
Question Containment Plan - When is a containment plan required and what should be included?
When is it required to conduct a containment plan and what should be included in that?
If containment plan is required should a run@rate be conducted????
Sponsored Links
Old 18th January 2000, 07:51 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I'm going to first suggest that you read: http://Elsmar.com/ubb/Forum12/HTML/000022.html - it has some discussion on containment.
Containment is the many things a company does when a problem is identified - internally or externally. Containment is just that - to contain. To keep from getting out.
Including:
* Identify part number and determine what has been shipped, when, what is in the hands of customers (in their stock - requires close contact with a customer 'point of contact'), what is enroute, etc.
* Determine when the 'event' occurred (like lot number).
* Isolate in-house and warehoused suspect product.
* Determine earliest and latest. Eg. Did test fail? When? Is this a 'standard' that went bad? In the case of a test instrument calibration, when was the last calibration? Can you test interim product to see if stuff in between is OK or where the calibration went far enough out as to allow nonconforming product to be 'passed' and shipped. What shipped product lots are 'suspect' and 'what's in the pipeline'?
* Close communication with customers to ensure 'timely' update on possible (suspect) lots or known 'contaminated' lots.
* The customer has to have knowledge of lots - what may they have shipped that was assembled with your suspect component.
What you do to ensure that product shipped from the point at which you know of the problem is 'Conforming' [HOLD EVERYTHING!!!! - What have we got here?] (often 100% inspection/test for the specific defect and then you 'certify' [as per the SS requirement, but typical outside the sector as well - can you say SORT?] each shipment for an agreed upon time period - which depends upon the problem identified, etc., as I'm sure you know). This is what you ship to the customer within X hours (not always considering reality). The intent here with the stated hours is to avoid interrupting a customer's manufacturing schedule.
You might also want to wade through: http://Elsmar.com/ubb/Forum4/HTML/000109.html
Run-at-Rate: if you change your process, this *may* be a part of the associated rePPAP.
[This message has been edited by Marc Smith (edited 15 February 2001).]
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Reference or recommendation of items to be included in the Business Plan Pancharee ISO/TS 16949 - International Automotive Quality Systems Standard 3 26th March 2009 10:21 AM
I need help with containment practices - First off/coil change containment lovingquality Manufacturing and Related Processes 4 18th August 2008 05:34 AM
Secondary Containment - What are the Requirements for Secondary Containment? elkel ISO 14001 and Environmental Related Standards 16 19th August 2007 11:23 PM
Containment FMEA and GP-12 (GM procedure for early production containment) Marc FMEA and Control Plans 9 17th November 2006 02:06 PM
What is the GP 12 Containment Procedure? bocky APQP and PPAP 3 7th March 2002 09:35 AM
The time now is 04:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
