Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th February 1999, 01:05 AM
Bill Smith
Unregistered Guest
Posts: n/a
Question PPAP and Part Sample Warrant (PSW) if a machine is moved
We are planning to move several molding machines from one side of the plant to the other side of the plant and the question of "do we need to re-submit for PSW approval has
come up. The PPAP manual requires that we
contact our "Part approval Authority" and if they do not require a PSW we would need a part number specific waiver.
OK that's easy, now the problem is that we have never PSW'd to a specific machine only to a specific tonnage of machine and the result is that we have almost 500 part numbers that would require a specific waiver.
And we all know the "The Customer" is not going to issue 500 waivers for this.
So how can we meet the intent of the standard without killing ourselves in the process ??
Thanks in advance
Bill Smith
Sponsored Links
Old 7th February 1999, 01:57 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
According to the PPAP manual "When PPAP submission is reguired" clause 8 "Production from tooling and equipment transfered to a different plant location....."
I understand this as meaning a different plant and not a change of location in the same plant. The reason INHO is that a different plant might work in a different manner etc, whereas if the machine is moved inside the same plant the overall system is the same.
"OK that's easy, now the problem is that we have never PSW'd to a specific machine only to a specific tonnage of machine and the result is that we have almost 500 part numbers that would require a specific waiver."
I have never been sure that the PPAP approval aplies to a specific molding machine. This is a problem as it means that according to this thinking you should supply PPAP for all machines in your plant to enable you the flexibility of production. This INHO is madness.
Sponsored Links
Old 8th February 1999, 01:07 AM
Forum Administrator
Karma Power: 195
Default
I missed clause 6 sorry.
I dont know. We have not related to this maybe we are wrong.
Can any one else help us.
I have a feeling that no one really knows.
You could always ask your registrar but this is dangerous.
Old 8th February 1999, 01:24 AM
Bill Smith
Unregistered Guest
Posts: n/a
Default
Thanks for the help Howard.I aggree that clause # 8 does not apply here
We feel that clause # 6 is where we might run into a problem. It refers to the rearrangement of existing tooling or equipment.
Would molding machines fall into this category as "equipment" ? That is the question we are worried about.
Bill
Old 13th February 1999, 08:33 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Moving equipment *can* require you to re-PPAP. But as to the waiver, ask for one waiver for a range of part numbers.
I doubt moving injection molding equipment will be a big deal. A big press, like a metal press, is more sensitive (differences in plant floor foundation / vibration / tool chatter issues, to name a few).
Does this help?
Old 21st February 1999, 12:01 PM
Batman
Unregistered Guest
Posts: n/a
Default
I have a real life story regarding moving equipment. We rearranged a portion of our injection molding department into a cell. Maintenance moved two 60 ton presses. One was "dropped" when a chain broke. It didn't hit the floor, but snapped tight against another chain. One of the operators nearby happened to see it. Nothing was said, and the machine started up fine, and parts were manufactured. Unfortunately, due to one of the ways (guides) being knocked out of alignment, a little flash had developed that broke off during shipping, causing a "chip" on a significant surface. We had a return. My investigation luckily found this operator. Now, when we move equipment, we do a layout and capability study, as a minimum. As good suppliers in the automotive world, we also now tell our customer we are moving a piece of equipment, and request a PPAP submission level.
Here's my take. After moving equipment, aren't you interested to see if anything changed? You may miss something that may influence the customer, but at least make the attempt. Knowing you are going to do this, you will already have information for the customer showing nothing changed. We have never been granted a waiver without some evidence - layout, PPAP data, etc. - that the parts did not change.
Obviously this is easier if you have 500 parts for one customer on that machine. If you make 500 parts for 500 customers, it could get a little more difficult qualifying. Perhaps a couple of capability studies for a couple of parts sent to all those customers would suffice. At the very least, you should generate some information on the parts from their first run to satisfy yourself.
Old 19th November 1999, 04:38 PM
David Guffey
Unregistered Guest
Posts: n/a
Hehehe...
Marc, how can you use the term "common sense" in any way related to QS-9000 without blushing? Of course, you might be, we just can't see that on the net.
As much as I hate to admit it, it does make good business and quality assurance sense to re-layout after the move of a major piece of equipment. The horror stories above are ample illustration. But, you might be pleasantly surprised at your customer(s). Once you've done your layout and you've determined all is well (or not and you fix it), let the customer know. If you can report what you've done and that all is well, you probably won't be asked to resubmit. Waivers no doubt will be granted. But, if you don't ask, you can bet your registrar will challenge you.
Old 20th November 1999, 01:19 AM
dewie dewie is offline
Involved - Posts
Registration Date: Sep 1999
Karma Power: 43
dewie has less than 100 Karma points so far.
I had an experience in electrical world. Once the operator bumped with one of the machine, the final characteristics were failed since the bending leg of capacitor was slightly shifted. All of the lot was rejected. Good luck that it was not sent to the customers.
Reply
Bookmarks
Tags
ppap
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
New PSW (Part Submission Warrant) - 4th Edition PPAP manual bigkevin APQP and PPAP 35 13th April 2009 02:38 PM
PPAP Approval - Customer approval of PSW (part submission warrant) Peters APQP and PPAP 5 16th November 2008 07:06 PM
PSW (Part sample Warrant) - Restricted or reportable substances Paul Mc APQP and PPAP 13 14th March 2007 10:46 PM
PSW (Part Sample Warrant) - When drawing and part numbers do not match mwarner APQP and PPAP 4 8th September 2005 02:22 AM
ISIR (Initial Sample Inspection Report) vs. PSW (Part Sample Warrant) Scott Hackler ISO/TS 16949 - International Automotive Quality Systems Standard 5 30th June 2003 10:11 AM
The time now is 05:33 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
