Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO and IEC Medical Device Related Standards > ISO 13485 - Medical Devices - Quality Management Systems
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st December 2003, 10:31 AM
Kristi Kristi is offline
Registration Date: Oct 2003
Karma Power: 25
Kristi has less than 100 Karma points so far.
Default Conversion from ISO 9001:1994 to ISO 13485:2003
Hi!
The company I work for is currently ISO 9001:1994 certified. We are in the process of converting to ISO 13485:2003.
The current quality system set up is quite complex and I would like to simplify it....
I would like some ideas on how others handle referencing SOPs or other documents. (I.e.: The current system here can have one SOP referencing 12 others; everything is very intertwined.)
Thank-you!
Sponsored Links
Old 1st December 2003, 12:55 PM
Cathy Cathy is offline
Registration Date: Jun 2003
Karma Power: 31
Cathy is appreciated, and has over 100 Karma points.Cathy is appreciated, and has over 100 Karma points.
Default
Hi!
Hi Kristi,
Welcome to the cove!
This is something that I would not like to do. Are you not going to upgrade to ISO9001:2000? I am sure you are aware that very few registrars (if any) certified to accredit ISO13485:2003.
One way you can simplify your system is to strip it back to the bare minimum. To start this the best thing for you to do is a GAP analysis of the current system and identify the areas where you must have a procedure and work from there - there will be quite a few differences. Have you implemented ISO13485:1996. If you have this may not be such a big jump.
This is the first time I have heard of a company converting from ISO9001:1994 to ISO13485:2003 have a look through the other threads in the section. There is some good advice!
Good luck,
Cathy
Sponsored Links
Old 1st December 2003, 01:43 PM
Aaron Lupo's Avatar
Aaron Lupo Aaron Lupo is offline
QA-LA
Registration Date: Jan 2000
Thanks Given to Others: 5
Karma Power: 71
Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.
Default
Originally Posted by Kristi
Hi!
Thank-you!
Kristi-
Welcome. When you say that your current system is complex, do you feel that it is because you have procedures referencing 12 others?? If that is the case when you revise your current procedures only reference what is necessary, there is no need to reference your training procedure in all your procedures (I am sure all employees are required to read your training procedure) so why restate the obvious same for document control etc...
Upgrading from ISO 9001:94 to 13485:2003 should not be that difficult have you looked at ISO 9001:2000 are you upgrading to 9001:2000 or as Cathy asked do you currently have 13485:1996 Certification? If not you do know that as of 12/15/03 your ISO 9001:1994 Certificate is no longer valid correct?
If you could provide a little more information we should be able to help you get past this.
Old 1st December 2003, 04:36 PM
Karma Power: 25
Default
Thanks for the welcomes!
In reply to your questions:
We currently are not certified to ISO 13485:1996. However we do follow it.
Yes, we do know that as of 12/15/03 ISO 9001:1994 is no longer valid. We looked at going to the 9001: 2000, but have decided to convert only to the 13485:2003.
By "complex" I mean that we definitely do not have a simple to follow or user friendly system.
I have looked at several of the threads and have found them helpful!
Old 2nd December 2003, 10:43 AM
wrodnigg's Avatar
wrodnigg wrodnigg is offline
CE or not CE?
Registration Date: Nov 2003
Thanks Given to Others: 4
Karma Power: 43
wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.
Default
Hello Kristi,
...when you upgrade to 13485:2003 (from ISO 9001:1994), you have to do several things:
One of the first things, you have to switch to a process-oriented system. There is a lot of literature (and threads in this forum) which can guide you, how to establish processes in your company.
I think, this could also help you to simplify your system.
On the other hand you have to fulfill the requirements of 13485:2003 which are especially designed for manufacturers of medical devices.
If you already follow 13485:1996, there is less work to do, but you will have to establish ~30 documented procedures and implement a strong system for quality records.
In "Annex B" of 13485:2003, there you find a comparison between 9001:2000 and 13485:2003 which can help to find out the additional working-items you have to implement.
Another hint could be ISO/DTR14969 (you can buy it at www.aami.org), which is a "guidance on the application of ISO 13485:2003"
To the referencing thing:
You could try to use the index of the Standard and make a matrix (e.g. an Excel Sheet) in which you show which requirement of the standard is implemented in which SOP, and which SOPs belong to the same processes. Or you start on the process-landscape and start referencing top down from there.
regards~ghw
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 SIMMO ISO 13485 - Medical Devices - Quality Management Systems 2 12th September 2008 01:43 PM
A Question of Sorts - Why register to both ISO 13485:2003 and ISO 9001 Pataha ISO 13485 - Medical Devices - Quality Management Systems 22 14th July 2005 05:00 PM
PS 9000 - PS 9004 & PS 9100 Pharmaceutical vs. ISO 13485-2003 and ISO 9001-2000 Ray cooke Other ISO and International Standards and European Regulations 2 20th June 2005 01:11 PM
Integrating ISO 13485:1996 with ISO 9001:1994 MiniP ISO 13485 - Medical Devices - Quality Management Systems 6 3rd October 2003 11:54 AM
Conversion from ISO 9001:1994 to 9001:2000 sneekparty ISO 9001 - Quality Management Systems Standard 3 18th June 2002 05:19 AM
The time now is 11:03 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
