3rd December 2003, 04:11 AM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Ok, here goes...
Sure Energy,
Is your screen resolution ok? (Right click on the desktop, pick properties and go to settings. Check the screen area settings). Try changing the settings. Did that help?
/Claes
3rd December 2003, 10:37 AM
An Early 'Cover'
Registration Date: Mar 2002
Karma Power: 103
Or, if the problem is in Internet Explorer, click view, then text size, then adjust.
Good idea, Sheriff.
Mike S. ("Gun Nut")
And they ask me why I drink....
3rd December 2003, 12:27 PM
Part-Timer
Registration Date: Oct 2003
Thanks Given to Others: 13
Karma Power: 38
Thread
I think the tiny font thread was
http://elsmar.com/Forums/showthread.php?t=7430
Under the coffee break talk heading, titled "looking for help" -- that one?
3rd December 2003, 02:03 PM
$ Contributor
Registration Date: Nov 2002
Karma Power: 37
XP Home
Originally Posted by energy
Windows XP-Home version. Even with my 14" monitor, I have never had to use magnifiers to see the icons and all associated fonts. I tried everything within my undersized cabeza to make them bigger. Any help out there? This thread can be a sounding board for all those people new to the world of computers and nobody will scoff at the question. (And get away with it) I promise. Okay, here we go!
Hello Energy, I had the same problem with my XP Business edition. I messed with it one two many times and ended up without a screen of any sort except black!  I took it in to the computer store and a tech said I had my resolution set to high and that the computer was set up to use two monitors. He fixed it and disabled the two monitor option and now I don't screw around with it anymore!  Good Luck.
Paula
3rd December 2003, 02:15 PM
Metal Bob
Registration Date: Oct 2002
Karma Power: 45
Try changing the resolution to 800x600 or 1024x7??.
Even with a 21" monitor at work and 30 year old eyes anything higher and I'm squintting all day!
Right click anywhere on desktop area (not on an icon).
Select properties.
The last tab on the right (display?) change the resolution to something smaller.
SOmewhere in the properties box there is the option to select font sizes/styles
example XP Standard, large, extra large. (Sorry no XP at work to get exact WORK INSTRUCTIONS OR PROCEDURES  ).
What exactly am I signing for here? Where's the packing list? PO? Customer Requirements? - Want to play some Xbox360 on Live?
6th December 2003, 01:47 PM
If I had known
Originally Posted by little__cee
little-cee,
You are correct. If I had remembered, I would not have started another thread on computer problems.
11th December 2003, 05:35 PM
An Early 'Cover'
Karma Power: 103
Usb
Let's say I buy an external device -- maybe an external hard-drive or CD-RW -- for my computer and the new device says it connects via USB 2.0. Can I still use it on my 3 year old computer that only has the earlier (USB 1.0?) USB capability?
Mike S. ("Gun Nut")
