Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th February 2000, 11:01 AM
SRTipton
Unregistered Guest
Posts: n/a
I Say... PPAP Rev 3 Cpk/Ppk - Bulk Suppliers - Aluminum, ingot, coil
There appears to be some leeway for bulk suppliers like my company(ie, aluminum, ingot, coil) regarding PPAP Rev 3 Cpk/Ppk requirements. I'm not sure that my interpretation is correct but if a supplier-designated key characteristic is not in statistical control, then the reporting for PPAP should be by Ppk. We use a monthly Cpk/Ppk report to satisfy ongoing process capability (since our customer has no key characteristics identified for us). We have a prior interal audit nonconformance written against a process with a Cpk < 1.33. For the last 8 months the Cpk has been > 2 but this past month, the process was not in control (out of control points were investigeated with no assignable cause found)so, Ppk was used on the capability report. Now, the Ppk is < 1.33. Can I close the nonconformance based on the prior 8 months or should I leave it open and shoot for > 1.33 on both Cpk and Ppk, even though this is a supplier designated key characterstics.
Sponsored Links
Old 15th February 2000, 07:55 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Yin Yang
I would think that if the process has been in control for 8 months and only briefly went out and is now back in and your investigation turned up nothing (we know we missed something, no?) I would think you could close it out. Problem is, we know there is an assignable cause - it's not noise - what will you do if it happens again in 8 months? Will anything 'trigger' you to come back to this incident (recurrence)?
Do see http://Elsmar.com/ubb/Forum10/HTML/000001.html
Cpk or Ppk: Which should you use?
Your customer has asked you to report the Cpk of the product you are sending. You know that to compute the Cpk, you need to have the product specifications, and that you need to have the mean and sigma. As you gather the information, someone asks, "which sigma do they want?"
You know that Cpk is calculated by dividing by 3 sigma. But which sigma should you use, estimated or calculated? Which is correct? Which would you report? Naturally, most of us would use the sigma that makes the Cpk look the best. But the sigma that makes the Cpk look best may not accurately reflect what you or your customer need to know about the process.
Confusion over calculating Cpk by two different methods is one reason that a new index, Ppk, was developed. Ppk uses the calculated sigma from the individual data.
Given that Ppk uses the calculated sigma, it is no longer necessary to use the calculated sigma in Cpk. The only acceptable formula for Cpk uses the estimated sigma.
In 1991, the ASQC/AIAG Task Force published the "Fundamental Statistical Process Control" reference manual, which shows the calculations for Cpk as well as Ppk. These should be used to eliminate confusion about calculating Cpk. So which value is best to report, Cpk or Ppk? Although they show similar information, they have slightly different uses.
Estimated sigma and the related capability indices (Cp, Cpk, and Cr) are used to measure the potential capability of a system to meet customer needs. Use it when you want to analyze a system's aptitude to perform.
Actual or calculated sigma (sigma of the individuals) and the related indices (pp, Ppk, and Pr) are used to measure the performance of a system to meet customer needs. Use it when you want to measure a system's actual process performance.
[This message has been edited by Marc Smith (edited 23 February 2001).]
Sponsored Links
Old 15th February 2000, 08:45 AM
SRTipton
Unregistered Guest
Posts: n/a
The Trigger would again be the monthly ongoing capability report. If the out of control condition continues in the next report, then we know we have lost our in-control process.
[This message has been edited by Marc Smith (edited 15 February 2000).]
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Questions on use of SPC, Ppk, Cpk during PPAP narakorn Capability, Accuracy and Stability - Process, Machine, etc. 10 27th February 2009 06:32 PM
Bulk Material PPAP (Resin Suppliers) pmwong APQP and PPAP 3 26th April 2008 12:41 PM
Machine issue in Cpk/Ppk and Control Plan - PPAP Submissions Jimmy_Nie APQP and PPAP 5 4th January 2007 01:45 AM
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Howard Atkins SPC Monitoring and Statistical Analysis Techniques 0 20th February 2006 03:41 AM
PPAP Appendix F.3 "Customer Plant Connection" - Bulk Materials - Steel Coil Supplier Tim M APQP and PPAP 4 27th March 2000 04:25 PM
The time now is 07:04 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
