Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th February 2000, 03:14 PM
Frank45
Unregistered Guest
Posts: n/a
Question APQP " Key Contact on Control Plans"
We are a manufacturing plant with Hundreds Control Plans in use. We recently had a organizational change that effected the Key Contact/Phone Item #7 requirement in APQP. What is a painless way of addressing this requirement to avoid updating control plans when primary contact personnel is changed?
Sponsored Links
Old 17th February 2000, 04:48 PM
billsfan
Unregistered Guest
Posts: n/a
Covering Ass
Frank,
Instead of using the person's proper name - use the postion title ie; Mfg. Eng. or Q.A Mgr. They names and faces may change but the resposibilities stay with the position.
Hope that helps!
Sponsored Links
Old 17th February 2000, 05:00 PM
Mike525
Unregistered Guest
Posts: n/a
billsfan:
The APQP Manual specifically calls out for a name and telephone number of the primary contact responsible for the control plan. I'm not sure if a position title alone meets that criteria.
Does anyone else out there use position titles alone and been audited by their registrar and not get a nonconformance?
Frank45: I know no one ever asks my opinion any more, but do you think simply posting or attaching a "controlled" sheet to the control plan which identifies the new key contact would be sufficient, and we identified the process in our FSIP that the name will be updated directly on the control plan the next time it is revised? Just thinking out loud.
Old 17th February 2000, 05:07 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I've only seen them with a position, a specific name and a phone number.
Old 18th February 2000, 01:17 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
As you do not have to resubmit the control plan for each change but merely keep an updated copy, and the name is there I beleive for mainly the PPAP stage so that there can be contact if neccesary, after the PPAP usually the responsibility moves from the engineering to the production and anyway the name changes. Use a blanket letter that shows the change, file it with the control plans and update when you update further infomation.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Control Plans - VDA equivalent of AIAG APQP & CP book? Jgryn VDA Standards - Germany's Automotive Standards 1 5th February 2009 01:27 PM
APQP & C/P Manual, Pg33, Para 3 - Control Plans - Clarification please mkbagwell FMEA and Control Plans 5 22nd July 2006 08:38 AM
Giving key contact information little__cee ISO 9001 - Quality Management Systems Standard 8 28th September 2004 12:50 AM
Control Plans - Intending to transfer our control plans to electronic format Paul Homer Documentation Control Systems, Procedures, Forms and Templates 7 20th September 2000 04:56 AM
APQP Control Plans - MSA studies for everything listed on the plan? Tom Avrutik Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 22nd March 1999 11:00 PM
The time now is 07:11 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
