Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th December 2003, 08:57 PM
Richard-jxb's Avatar
Richard-jxb Richard-jxb is offline
Registration Date: Dec 2003
Karma Power: 25
Richard-jxb has less than 100 Karma points so far.
Please Help! About StDev in MINITAB13
when I use MINITAB's Process Analysis(Betwwenn/Within), the results showed me:
StDev(Within)=
StDev(Betw)=
StDev(Total)=
StDev(Overall)=
But I don't know how to calculate the above.
Would you like to help me?
Sponsored Links
Old 16th December 2003, 10:01 AM
Dave Strouse's Avatar
Dave Strouse Dave Strouse is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 46
Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.
Default Look at the help screens for control chart I-MR (Between-Within)
Richard -
I'm assumming you mean capability analysis, MINITAB does not have a process analysis to my knowledge. Their help is a bit deficient here. However, the help for the I-MR controol chart within and between is the same method I believe. From that dialog, box click on help button then on see also. I cut and pasted it here, but you might want to look at it in your MINITAB as some of the symbols may not come through correctly. here
________________________________________________________
If you do not estimate parameters by historical groups, Minitab displays three standard deviations in the Session window. These are the standard deviations for the between component, the within component, and the total variation. These standard deviations can then be used as parameters in other analyses. For example, you might want to use the estimate for the total variation as the historical sigma in a normal capability analysis.
Here are the model assumptions used in estimating these three standard deviations. The model assumes that an observation, Xij, is the sum of an overall mean, m, a between component, Bi, and a within component, Wj(i), as shown below.
Xij = m + Bi + Wj(i)
i = 1, …, I; j = 1, …, J
The between components, Bi, are assumed to arise from a normal distribution with mean 0 and variance B. The within components, Wj(i), are assumed to be independent of the Bi and arise from a normal distribution with mean 0 and variance w. The total variance of the observation, Xij, T, is the sum of B and w.
The I Chart of the subgroup means gives an estimate, say V1, of Var(i), the variance of the subgroup means:
Var(i) = B + w / J
The Range Chart gives an estimate, say V2, for w. This is true because the Range Chart for the Xij is the same as the Range Chart for the (unobservable) Wj(i), the within component.
We can combine V1 and V2 to get estimates of B and w, as
estimate of B = max( 0, V1 - V2 / J )
and estimate of w = V1 + (J - 1) * V2 / J.
It is possible that the estimate for B is zero.
Sponsored Links
Old 16th December 2003, 11:33 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
Also see the following articles from Minitab Answers Database:
http://www.minitab.com/support/answe...er.aspx?ID=605
http://www.minitab.com/support/answe...er.aspx?ID=654
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Old 16th December 2003, 11:51 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
Excelent links Atul, specially the second ones.
Within Sample Stdev = Range_Average /d2 or Stdev_Average/c4
(wich method depends on the sample size, some say that Range is used with subgroup sizes less than 10, but is the ones that is used to chart SPC and capability index; cpk, cp, cpm, cpmk)
Between Sample Stdev = Excel Stdev on the averages of each group /c4
Total Variation Stdev = Excel Stdev on the data / c4
(the ones for performance index; ppk,pp)
c4 is used to change values from biased to unbiaded estimates.
Excel Stdev is the traditional way to calculate stdev.
And in some texts, Overall an total are the same.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Overall and Within/Between STDEV - Why not the same? puck1263 SPC Monitoring and Statistical Analysis Techniques 19 31st August 2009 03:29 PM
Does Excel STDEV calculate in 3 stdev (standard deviation)? T Dutton Excel .xls Spreadsheet Templates and Tools 12 6th February 2007 01:09 PM
The time now is 08:10 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
