10th November 1999, 04:43 PM
PPK Requirements & MSA Studies for PPAP
We recently had a continious assessment from KPMG and the auditor gave us a minor nonconformance for not including Accuracy, Linearity and stability studies along with a GR&R in a PPAP submission. Our question is , are all of these statistical studies required? or are they optional.
Any help to clear up the confusion would be helpful.
11th November 1999, 12:59 AM
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
The PPAP manual does not detail what is actual required in terms of documentation.
I think that the demand for the additional data is "harsh".
The PPAP was approved as submitted and this should be the test. If you fulfilled the customer requirements to his satisfaction I do not see how the Registrar can fault this.
11th November 1999, 03:58 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
I haven't seen them required in a PPAP package before.
11th November 1999, 12:09 PM
Registration Date: Sep 1999
Karma Power: 90
Refer to 4.11.4. It appears that your auditor may be referring to this para. to determine analysis content for the GR&R.
11th November 1999, 12:30 PM
The auditor may have been peeling back one layer, and was simply asking how do you prove to your customer that your GR&R accurately reflects your true measurement capabilities.
The statistical tests for bias, stability, and linearity show the impact of the environment on the measurment system. When these are shown to have a neglible effect upon the measurements taken, then the GR&R results more accurately reflect the system's capabilities.
Depending on what your measuring, where you're measuring it, and the tolerances you're measuring to should drive what type of statistical testing you do for your measurement system analysis, as well as any stated customer requirements.
But, with all that said and done, Howard and Marc are right, these tests aren't specific stated requirements for PPAP. It's not against the rules to question your auditor, and ask him or her clarify or to point out the source of the nonconformance.
11th November 1999, 04:06 PM
Karma Power: 605
5 years ago the question was pretty much "Are you calibrating appropriate equipment?" The evolution has been to a holistic and 'educated' approach (not many people even heard of 'Uncertainty' 5 years ago and even now few auditors understand it). Howard, Mike and Sam are right, I believe. You have to show evidence - but as an actual part of the PPAP package - well, I haven't heard that specific info requested.
11th November 1999, 04:45 PM
Thank's guys, That is what we wanted to hear, Please keep the answers flying this way, I'll post the results of the review when we get it back.
17th November 1999, 04:39 PM
weel in my understod you will be define a procedure or work instruction if it says you will be used YOU MAY BE HAVE IT.
I´M WRONG ?
