Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th January 2004, 08:35 AM
dbulak's Avatar
dbulak dbulak is offline
Involved in Discussions
Registration Date: Aug 2000
Thanks Given to Others: 54
Karma Power: 41
dbulak has less than 100 Karma points so far.
Question Is it possible to determine the Cpk value from Cp and Cr values?
Is it possible to determine the cpk value just by having the cp and cr values?
Sponsored Links
Old 12th January 2004, 09:15 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default Re: cpk
I'm not sure there is a relationship. Cr is defined as the reciprocal of Cp (Cr = 1/Cp). These are two ways of comparing the total tolerance with total (6Sigma) process spread. Process centering is not considered.
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Sponsored Links
Old 12th January 2004, 09:19 AM
The Taz!'s Avatar
The Taz! The Taz! is offline
Courtesy Access
Registration Date: Nov 2003
Thanks Given to Others: 1
Karma Power: 46
The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.
Send a message via AIM to The Taz! Send a message via Yahoo to The Taz!
Default Re: cpk
The Cpk will equal the Cp IF and ONLY IF you are dead on target. This is a rare case. Cr is your % of B/P tolerance consumed by the process (Inverse of Cp). Helpful index, but you need to take process center location into account to determine Cpk.
Cp does not take process location into account and is a process capability index assuming you can center the process to obtain a reasonable Cpk. A process with a Cp of 4.0 will produce 50% rejects if centered on one of the tolerance limits.
Hope this helps. . .
Old 12th January 2004, 11:10 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default Re: cpk
dbulak you said.
Is it possible to determine the cpk value just by having the cp and cr values ?
Atul is right, Cr = 1/Cp and as Taz said Cp= Cpk if centered on target (Cpk is always less or equal to Cp).
The question is if you hace specs and mean also, if such the case,
Cp = (USL - LSL) / (6 * Sigma) or Sigma = (USL - LSL) / (6 * Cp)
Cpk = min ( USL - mean, mean - LSL) / (3 * Sigma)
Cpk = min ( USL - mean, mean - LSL) / [3 * (USL - LSL) / (6 * Cp)]
Cpk = min ( USL - mean, mean - LSL) * (2 * Cp) / (USL - LSL)
If only specs are available, you could use target insteed of mean, I readed somewhere in the Milstd hanbooks (but always document the asumptions ie. on target).
Cpk = min ( USL - target, target - LSL) * (2 * Cp) / (USL - LSL)
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
Old 12th January 2004, 11:25 AM
Rob Nix's Avatar
Rob Nix Rob Nix is offline
qualitas ad nauseam
Registration Date: Sep 2003
Thanks Given to Others: 3
Karma Power: 79
Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.
Default Re: cpk
The short answer then, to dbulak's question, is NO. If all you know is cp / cr, you cannot determine the cpk. If you get one more metric - the mean - then you have enough to determine cpk (assuming you know the USL/LSL and std devs).
Rob - The sum of anecdotes is not data. -Roger Brinner
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Can someone share an Excel spreadsheet to measure Cpk or Cp values. qltyperson1 Excel .xls Spreadsheet Templates and Tools 15 18th September 2009 07:50 AM
Is the normal Cpk calculation applicable for data with positive & negative values? Anonaman Capability, Accuracy and Stability - Process, Machine, etc. 4 11th August 2009 08:54 AM
How to determine the values of k1, k2, k3 in Gage R&R fl350z Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18 7th May 2008 11:44 PM
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Howard Atkins SPC Monitoring and Statistical Analysis Techniques 0 20th February 2006 03:41 AM
Capability study - What Values do I have to input to calculate Cp and Cpk NetScorpium Capability, Accuracy and Stability - Process, Machine, etc. 9 20th December 2004 05:33 AM
The time now is 12:28 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
