12th January 2004, 12:52 PM
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
Seeking: Powder Coating Test
Are there any experts in this field? Looking for a test or method to determine if a piece of steel is powder coated? Any help is appreciated. Thanks in advance.
12th January 2004, 01:01 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Re: Powder Coating
You might send a Private message or email to Cove member Sue, who is a Powder metal maven.
12th January 2004, 01:17 PM
Involved - Posts
Registration Date: Oct 2003
Karma Power: 37
Re: Powder Coating
It has been awhile since I was into the coatings that get applied to Steel. Powder coating usually has a more distinctive surface appearance, and greater film thickness than say an E-coat. If you can check the film thikness try doing so. If not try scribing the surface as if you were going to run it in a salt spray test as a panel.
12th January 2004, 01:25 PM
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Re: Powder Coating
What are you looking for in particular??
Are you having trouble telling if something is e-coated or powder coated??
Kevin
"Without theory there is nothing to modify or learn." W. Edwards Deming
12th January 2004, 01:52 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Re: Powder Coating
I wish I had my notes from Stolle - there are different tests for each. I was introduced to them - I'll have to see if I have anything here (don't think I have) - when Harley started rejecting product and I found they were using an e-coat test on powder coat. It was Harley's mistake but it took me several days to figure that out.
13th January 2004, 11:35 AM
Involved - Posts
Karma Power: 37
Re: Powder Coating
gpainter - I found some old business cards with the phone numbers for PPG Tech Rep I used to work with. If you want them send me a private message and I will give them to you.
14th January 2004, 02:02 PM
Quality Team
Registration Date: Jun 2002
Thanks Given to Others: 87
Karma Power: 127
Years ago we used a "Toke" Gage to scribe thru the primer to the substrate, and it has a graduated scope to look into and see the measurement of the thickness of the primer in mils. This was a Ford requirement on all our primed parts.This gage was inexpensive, and easy to use. All floor inspectors used it, and recorded the thickness. It may work on powder coatings, if that is what you are refering to.
"Nothing is constant except change"
14th January 2004, 03:14 PM
Karma Power: 605
Dave Scott wrote and said he's having trouble posting. He asked me to post this:
I wanted to answer gpainter 's question on testing for powder on parts so how about if I answer you and you can post it. To test for Phosphate coating on a steel part, place one drop of Nitric acid on the part. If it turns bright blue immediately, it is coated. If it is not blue, there is none.
