Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th January 2004, 01:20 PM
QCNerd QCNerd is offline
Registration Date: Jan 2004
Karma Power: 24
QCNerd has less than 100 Karma points so far.
Please Help! Seeking Best Practice of Parts Segregation
Does anyone have a Best Practices experience with parts segregation procedures at a metal stamping facility? Looking for ideas....we usually make 1 part stampings and out the door they go. But now we are going to make 19 different skus from the same die, just replacing some inserts, and we cannot have any of the 19 skus. And oh, they also go to a plater, come back and we finish assemble. We will have a vision system at the end of the assembly machine but we want to avoid any parts cross contamination issues before they get that far...
Looking for Best Practices in Cleveland...
QCNerd
Sponsored Links
Old 29th January 2004, 02:49 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
QCNerd
Having dealt with similar situation in machining facility (10 variations in length of a turned part - practically identical without resort to micrometer, including trip to and from plater), I have two suggestions prior to return from plater:
  1. manufacture each variation on different day or different shift (clear out all previous variation before beginning work on next)
  2. maintain segregation at plater (different variations on different days)
For return from plater:
  1. Create special packaging for each variation for return trip from plater
At assembly (depends upon whether all or only some of each variation go into final assembly):
  1. Only provide assembler with pertinent parts, lined up in specialized packaging
  2. Create assembly pattern which uses variations in correct order. (If same variation is used in two separate places on same finished assembly, assembled in different order, then provide TWO packages of the variation in the correct order of assembly)
The option open to us as machinists is not open to you. We created meaningless (except for identification) nonfunctional grooves on the different variations for easy visual ID without resort to micrometer. Even the plater could readily distinguish between parts in event of mixup (piece parts dropped into tank one day, retrieved the next, etc.)
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calculating PPM - Standard practice to calculate PPM from parts returned? Dawn SPC Monitoring and Statistical Analysis Techniques 21 4th November 2009 03:22 PM
GTP (Good Tissue Practice) & GLP (Good Laboratory Practice) Certification se123 FDA (United States Food and Drug Administration) 1 31st January 2008 12:21 PM
Seeking: Internal Audit Training Material - Practice Audits? Ingeniero1 Internal Auditing 14 11th January 2005 06:40 AM
Seeking: Origin and History of PPM (Parts Per million) gpainter SPC Monitoring and Statistical Analysis Techniques 3 15th January 2004 04:36 PM
Control of NCM: segregation strategies sulkinsf QS-9000 - American Automotive Manufacturers Standard 1 19th September 2000 03:14 PM
The time now is 08:30 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
