Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th July 2000, 10:30 AM
1236 Paul
Unregistered Guest
Posts: n/a
Question Capability Study for Level 3 PPAP - They are asking for a 100 peice capability study
I have just completed a level 3 ppap for a customer (first one I have done) and they are asking for a 100 peice capability study, I don't know what this is, can anyone steer me in the right direction. Thanks. Paul
Sponsored Links
Old 12th July 2000, 11:45 AM
billsfan
Unregistered Guest
Posts: n/a
Covering Ass
Paul,
First, you'll need to know what characteristic(s) are "critical." In other words, what dimension are you to do a capability study on? Once that is established, you need to collect 100 samples (parts) to preform the study on. Now, you say that you've just completed the PPAP, so I'm assuming that production ran some quantity of parts. Let's hope that they ran at least 300 pieces, since that is the minimum required in the PPAP manual. You take your 100 pieces out of that production run. If possible, samples should be taken over time ( some from the beginning, middle & end of the run.) You then would measure the 100 pieces,(remembering the 10x rule.) At this point, I would enter the numbers into a software system which calculates & reports Cpk/Ppk information. If you don't have software, I guess you're going to have to do it the old fashion way, paper & pencil. Formulas can be found in the PPAP manual. You'll also need a Gage R&R for the piece of measuring equipment used for the study. In the future, might I suggest that PRIOR to the PPAP run, the "critical characteristics" are identified and a plan is established to collect data on the floor at the time of manufacturing (ie; xbar & r chart.) Then all you have to do is collect the data from manufacturing & crunch the numbers. Hope this has been of some help. If you give me more specifics, I might be able to "walk you through" this capablity study. Good luck, and may the force be with you :-).
Sponsored Links
Old 12th July 2000, 05:24 PM
Don Watt
Unregistered Guest
Posts: n/a
Nice summary for capability study, just one question ....... What's the 10X rule?
Old 2nd August 2000, 05:50 PM
gerard jordan
Unregistered Guest
Posts: n/a
paul, just a few points though by now i'm sure you've attended to the matter. sounds like you had some good advice from fellow netters. On point of control charting etc make sure you do this manually and not via some software package. Do this for some time it's the only way to learn on such matters.
Secondly, make sure that process operators become involved in this process, ie, they contribute their wealth of knowledge and experience in determining what makes the process tick (ie, causes of varuiation)..
Thirdly, before you undertake to determine process capabilities you must firstly acknowledge whether or not the process is stable else all other efforts could prove futile.finally,is there anyone else in the plant who could undertake this study? If there isn't then something's wrong!
good luck with everything anyway.
Old 11th August 2000, 04:48 PM
billsfan
Unregistered Guest
Posts: n/a
Covering Ass
Don,
What I meant by the 10x rule is to be sure that the piece of measuring equipment used has resolution to one decimal place beyond the specification you're measuring. In plain english if you need to measure something .xx inches, you need a tool that will measure out to .xxx.
I've probably made that as clear as mud! You'll have to excuse me, Delphi has been using me as their whipping boy this month!
I'm not sure if I should s**t or wind my watch!
Anyways, back to the group....
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Capability Study Template alexoigres Capability, Accuracy and Stability - Process, Machine, etc. 1 17th January 2008 04:31 PM
Capability Studies - Fewest Number of Parts for a Capability Study ivo Capability, Accuracy and Stability - Process, Machine, etc. 9 20th June 2006 04:25 PM
Template for Capability Study narfeldt SPC Monitoring and Statistical Analysis Techniques 9 22nd June 2001 03:19 AM
PPAP Capability Study - Infrequent batches - Conductor paste Chantal P Tardif APQP and PPAP 6 16th March 2001 09:48 AM
Capability Study - Feasible? Capability Study when there is No Set Target Value precabcorp SPC Monitoring and Statistical Analysis Techniques 2 27th February 2000 11:08 PM
The time now is 09:27 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
