Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Process Audits and Layered Process Audits
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th February 2004, 05:26 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default New to Internal Process Auditing
I received this by E-Mail.
Lets help .
Hello!
I couldn't find where I would begin a thread, so I thought I'd go this route.
Our company produces the pigments for glass, ceramic, plastic, etc. We're a Tier III contributor for Ford, GM and DaimlerChrysler. Our company downsized, and I am now the "lead" auditor; however, I'm not real familiar with each process center.
How do I process audit but still make sure I cover all the "shall's" in the standard?
Should I make lists of questions pertaining to standard for the Quality Manager then zero in on customer complaints?
Then make a list to take out to our production area to find inputs, outputs, SOPs, take a portion of an SOP and audit, a product from the area then follow it back through the process through customer service?
Would you happen to have any sample process audits that would give me an idea of how I should set them up and what I should look for?
Thanks for any input you can relay.
Sponsored Links
Old 6th February 2004, 09:09 AM
Rob Nix's Avatar
Rob Nix Rob Nix is offline
qualitas ad nauseam
Registration Date: Sep 2003
Thanks Given to Others: 3
Karma Power: 79
Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.
Default
Howard,
At my last quarterly audit we switched over to a "process oriented audit" format and ran into the same concern you have (especially since I have a single audit format to audit two ISO9K2K facilities and one QS/TE facility). Our solution was to use a specialized interview sheet (attached below). We have close to 20 different processes, therefore 20 different customized interview sheets. Perhaps this will help a little.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf Process Audit Interview Sheet - manfg.pdf.pdf (95.9 KB, 1340 views)
Rob - The sum of anecdotes is not data. -Roger Brinner
Sponsored Links
Old 6th February 2004, 10:24 AM
Jodi G's Avatar
Jodi G Jodi G is offline
Registered Visitor
Registration Date: Jan 2004
Karma Power: 24
Jodi G has less than 100 Karma points so far.
Default Thank you.
Thank you Mr. Atkins and Mr. Nix for your help. I appreciate the Process Audit Interview Sheet. The questions for our Manufacturing area actually cover exactly what you have outlined. I like the format that you have.
Once I complete my audit sheet, I am assuming I log it into my audit schedule. I listed my main processes (HR, Purchasing, Receiving, Manufacturing, etc.) across the top of an Excel spreadsheet along with the Manufacturing process areas (Requisitions, Tunnel Kilns, etc.) and the APQP, SPC, FMEA, PPAP and MSA. Vertically, I have listed each element of the standard. I will then put the corresponding report number into the corresponding box. It is divided into quarterly audits since we conduct Central Quality Committee meetings quarterly.
Does that sound like I've set it up properly or is it too much? If anyone has any suggestions, I would appreciate them. Thanks.
Old 6th February 2004, 10:34 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
#1 - You do not have to cover all the shalls of the specification in a process audit. There are three types of audits required; QMS, Mfg. process, and product audits.
#2 - Attached is a "turtle" diagram that can be used to determine the contents of the process. Even if the process is already eastblished you can use this tool to familiarize your self with the process.
#3 - Once you are familiar with the process, use the tool that Rob attached for your audit.
Sam Goody
Old 6th February 2004, 12:34 PM
Jodi G's Avatar
Registered Visitor
Karma Power: 24
Default
Thank you for your assistance!
I previously posted a question as to my audit schedule. I think it's a little overkill. I think what I'm doing is reading too much into it to make sure I cover ALL bases.
Old 6th February 2004, 05:29 PM
Jodi G's Avatar
Registered Visitor
Karma Power: 24
Question
Would there happen to be a list showing the process area of, for example, Purchasing, and which elements are applicable to it? Then, one for HR and its applicable elements, etc.
Old 9th February 2004, 08:19 AM
RCBeyette's Avatar
RCBeyette RCBeyette is offline
When in doubt - THINK!
Registration Date: Jan 2002
Thanks Given to Others: 113
Karma Power: 217
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to RCBeyette
Default
Out of curiousity, Jodi, have you had any formal training to be a Lead Auditor? Some of your questions could probably be answered if you attended a Lead Auditor course (i.e., process-based approach, developing a suitable schedule, etc.).
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
Old 16th February 2004, 09:36 AM
Jodi G's Avatar
Registered Visitor
Karma Power: 24
Default New to Process Auditing
Roxanne:
No, I haven't taken the Lead Auditor course, only the Internal Auditing with Emphasis on ISO/TS. Actually, I took the class in Dec '02. Our 3rd party TS auditor required that I retake the same class in Dec '03 because Ford changed their Internal Auditor requirements. There was no one on site who was qualified to audit to TS.
He actually recommended I take the Lead Auditor course during 2004.
Jodi
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process based Internal Audits, instead of auditing to the elements of the standard 5litre Internal Auditing 21 18th July 2007 12:56 PM
Internal Process Auditing - Auditor Unhappy - Wants Layered Process Audits jkittle Process Audits and Layered Process Audits 13 11th November 2006 09:31 AM
Converting to Process Audits - Seeking: Process Audit Form layout Craigbachler Process Audits and Layered Process Audits 4 6th October 2005 09:21 AM
ISO 9000:2000 Internal Auditing Resource Books - Process Auditing Sirlard Process Audits and Layered Process Audits 5 9th March 2004 01:41 AM
'Process Approach' to ISO 9000 Internal Audits - Identify an 'owner' for each process M Greenaway Internal Auditing 15 4th July 2003 03:27 AM
The time now is 07:45 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
