Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th May 1999, 07:58 PM
Luis Alves
Unregistered Guest
Posts: n/a
Let Me Help You Gage R&R studies and control plan for PPAP - Critical or Significant characteristics?
Hi
The R & R studies, should be made to all equipment's refereed in the control plane, or only the ones that measure critical or significant characterises
Sponsored Links
Old 29th May 1999, 04:07 AM
Chad Eilers
Unregistered Guest
Posts: n/a
Default
Only measurement systems used on the "key / sinifigant characteristics" must have Gage R&R studies done on them. However, some auditors would LIKE to see them done on all, but it is not required.
Sponsored Links
Old 29th May 1999, 05:37 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
I am sorry to dissapoint you but 4.11.4
Appropriate statistical studies shall be conducted to analyze the variation.........This requirement shall apply to measurement syatems referenced in the control plan.
Old 30th May 1999, 08:02 PM
Luis Alves
Unregistered Guest
Posts: n/a
Default
Ok
All measurement systems referenced in the control plan, should have appropriate statistics studies, but if a study is made for a measurer system, for instance a calliper, this study is valid to that measurement system although it is use in a lot of control plans?
Old 3rd June 1999, 08:30 PM
Batman
Unregistered Guest
Posts: n/a
Default
Hi Luis:
We have used the same results from a measurement system study for other areas, as long as we determined that the methodology was the same. Likewise, we have used one 0-6" caliper and applied the results to other areas that use 0-6" calipers, wven if they are not the exact same calipers.
You should be careful when determining when to do this. If you have 8 stations and 8 sets of identical measurement devices, measuring like features, you could decide to only use a couple of these for the R&R determination.
Also, the actual R&R result - the actual error, not the % of tolerance result - could be applied to another tolerance on another part, again if the measurement ssytem is similar enough.
Old 29th June 1999, 06:02 PM
Lassitude
Unregistered Guest
Posts: n/a
Exclamation
I agree with this for EV not AV. Let's say you have a caliper with an R&R on a part dimension from part X measuring 10.0 mm. It is a flat, easy to measure dimension on a piece. Then, with the same instrument, you measure a 'hard to reach' dimension on another part of 0.5 mm. While the EV should remain approximately the same (though different part of the equipment range), AV can vary significantly.
Old 29th June 1999, 06:31 PM
ALM
Unregistered Guest
Posts: n/a
Question
What I am interested in, and heard a bit about at a training class for MSA...
How much stock in the Gage R&R studies can their be? I mean, for instance, if I am measuring a part that is 108mm X 25mm, and it is a pressure-sensitive fabric... it isn't REALLY possible to expect that three people using vernier calipers are going to measure each of 10 parts in EXACTLY the same spot as each has previously measured... let alone one person to the next.
Think about it... that type of "exactness" is a requirement of an effective measurement system study... or was I misinformed? If I measure the 25mm dimension on the left-third of the part on one pass, the middle on the second, and the right on the third... how does that truly impact the result?
Thoughts? Comments?
ALM
Old 2nd July 1999, 03:38 PM
Luis Alves
Unregistered Guest
Posts: n/a
Question
What does it means EV and AV?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Critical / Key / Significant Characteristics - Special Characteristics Classification MasterBB FMEA and Control Plans 1 10th September 2009 06:16 PM
Critical or Significant Characteristics or Key Indicators Ranking mentor FMEA and Control Plans 7 4th September 2009 03:29 PM
Gage R&R Studies - 1200 operators, 2000 measurement tapes and many characteristics sylwia Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 4th April 2007 11:03 AM
Significant & Critical Characteristics Control Plan - Automotive Metal Stampings deanklewis FMEA and Control Plans 5 7th July 2006 07:32 PM
PPAP - No Critical Characteristics on Print 1killercls APQP and PPAP 22 23rd August 2005 12:05 PM
The time now is 11:11 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
