Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 9th March 2004, 09:58 AM
Douglas E. Purdy Douglas E. Purdy is offline
Courtesy Access
Registration Date: Apr 2002
Thanks Given to Others: 10
Karma Power: 58
Douglas E. Purdy has disabled his/her Karma.
Default Inspection & Test System
I am in a quandary over the Inspection & Test System, which leads to concerns with the control of nonconforming product. But first the Inspection & Test System - The evidence of conformity throughout In-Process and Final Inspection is primarily "acceptance" or "OK." The only evidence of conformity that gives the actual measurements is in Receiving Inspection, some set-up verifications (primarily involving CNC operations), and when the customer requires an Inspection Piece Report. I feel uneasy about this system, but this is the established system. I would appreciate feedback on if this system is okay and why, or this system needs more evidence of conformity and why.
Thanks,
Doug
Sponsored Links
Old 9th March 2004, 10:31 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Thanks,
Doug
Doug,
What you are describing is basically the way our mfg. and receiving inspection processes operate. All of our in-process inspection is visual. We do have visual aids and evidence of training. We follow up with product audits each day, which areslso visual.
Receivinfg inspection is where the actual measuring and testing takes place, however, the majority of the product is accepted with visual inspection using samples.
The system is documented on the control plan, work instructions and training records. It's been acceptable through QS,TS2, ISO and Ford Q1 audits with no NCR's. We did have a couple of OFI's.
Sam Goody
Sponsored Links
Old 9th March 2004, 12:34 PM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 24
Karma Power: 103
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
Default
Thanks,
Doug
Well, I see no clear violation of 8.2.4. I assume someone measures the product and says "okay" or "bad" and generates a record to that effect, but there are no quantitative data shown. So long at this matches their procedures and there is no evidence of serious problems such as customer returns related to poor testing, I'd say it is okay, but maybe not how I'd do it. JMO.
Mike S. ("Gun Nut")
And they ask me why I drink....
Old 10th March 2004, 09:59 AM
Courtesy Access
Karma Power: 58
Default
Originally Posted by Sam
Doug,
Sam,
Unlike your system, our In-Process and Final Inspections are not just visual but involves a number of dimensional characteristics. Would that make a difference to you in your resonse to the initial inquiry?
Doug
Old 10th March 2004, 10:17 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
Doug,
Only to say that, if you have dimensional characteristics you cannot use the term "accept/reject" or any other attribute term. You would need to document the measured result. Also with variables data comes the need for in-process SPC.
So, yes, I wouild also be concerned with the present status of the process.
Sam Goody
Old 10th March 2004, 10:49 AM
An Early 'Cover'
Karma Power: 103
Default
Doug,
Sam,
Please tell me where these requirements are stated. Where does it say I need to document the measured result for variables data and that I must have in-process SPC for it? I don't see it in ISO 9001. Maybe it is a TS or QS thing?
Mike S. ("Gun Nut")
Old 10th March 2004, 10:58 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
Originally Posted by Mike S.
Sam,
True. It comes from TS/APQP/PPAP/Customer Specific Requirement documents. However, the requirement should also be "flowed" down from a tier I to the tier II who may only be ISO 9001.
Sam Goody
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Test records shall show actual test results data - 8.2.4.1 Inspection documentation clara AS9100 Aerospace Standard and Requirements 4 26th January 2007 12:37 PM
How to Provide Evidence of Product Conformity during Manufacture? chum84 ISO 9001 - Quality Management Systems Standard 10 10th August 2006 03:15 AM
Evidence of Product Conformity Steven Truchon ISO/TS 16949 - International Automotive Quality Systems Standard 1 15th October 2004 03:45 PM
Inspection & Test System for Distribution Centers Douglas E. Purdy Inspection and Test, Sampling and Related Topics 4 2nd July 2004 09:45 AM
Need 3 appraisers for GR&R of the automatic test measurements? Calvin Chen Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 20th December 2003 09:49 AM
The time now is 01:28 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
