Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO and IEC Medical Device Related Standards > ISO 13485 - Medical Devices - Quality Management Systems
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th March 2004, 12:28 PM
Dave-h's Avatar
Dave-h Dave-h is offline
Involved in Discussions
Registration Date: Mar 2004
Thanks Given to Others: 33
Karma Power: 24
Dave-h has less than 100 Karma points so far.
Question Medical Electrical Equipment & UL approval
I was wondering if anyone had any experience with electrically powered medical equipment and gaining UL approval.
The safety aspects are covered by the various sections of 60601. This particular tool, has some control logic connected to the trigger that controls the operation of the tool.
Because the tool now incorporates sofware, UL require us to ensure that this element complies with 60601-1-4.
If anyone is familiar with this, how did you interpret the life-cycle diagram, so that you could produce a plan that meets their requirements?
p.s. I'm sorry if this message is "off-topic" because it is not strictly 13485.
Many thanks,
Sponsored Links
Old 16th March 2004, 12:00 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
Many thanks,
If you are refering to the Development Life-Cycle, you may find the attached helpful. There are references to FDA type documents like, 510K (Similar to CE STED) And Device Master Record (Similar to CE Technical File) but otherwise I think it conveys the idea.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Al
Sponsored Links
Old 16th March 2004, 12:29 PM
Dave-h's Avatar
Karma Power: 24
Default
Thanks Al,
That certainly looks that it will be useful.
Part of my problem is interpreting a standard that was probably created with complex life support systems in mind, as opposed to our relatively simple product.
Thanks again for yoir help.
Dave
Old 16th March 2004, 12:40 PM
wrodnigg's Avatar
wrodnigg wrodnigg is offline
CE or not CE?
Registration Date: Nov 2003
Karma Power: 43
wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.wrodnigg is appreciated, and has over 700 Karma points.
Default
Hello Dave-h, welcome at the cove
Maybe this document helps you a little bit with UL...
To the 60601-1-4 thing:
The Development Livecycle in 60601-1-4 is similar to the SDLC for Computerized Systems (just ask Google for "SDLC" and you will find plenty of information).
The Lifecycle Model (V-Model) can be read as follows:
On the left branch, you have specifications going downwards more and more into detail. Beginning with User Requirement Specifications (URS), detailed into Functional Specifications (FS) needed to meet the URS [here they are divided into FS of subsystems) and Design Specs (DS) of components which are needed to implement the functions of the FS.
In Phase 2 there is also the Risk Assessment (see ISO 14971 for details).
At the bottom of th "V" there is the system build.
Then you go up the verification branch, starting with module tests and component tests. A verification plan shows the relation between the tests an the specifications of the design specs.
Next is the functional testing against the subsystem-FS (guided by a verification plan).
Then you have the integration and system verification against the functional specs.
Finally there is the system validation to test if the system meets the URS.
So you have tests for all kinds of specifications plus tests for risk aspects from the risk assessment. The horizontal curves indicate verification- and validation-plans (documents which include test definitions and acceptance criteria).
This SDLC is also described in the GAMP4-Guide.
If there are any further question, just ask...
And if you want just a simple way, look at the V-Model in the GAMP4-Presentation. It is quite similar to the Lifecycle of 60601-1-4
regards~ghw
Thanks to wrodnigg for your informative Post and/or Attachment!
Old 17th March 2004, 04:39 AM
Dave-h's Avatar
Karma Power: 24
Default
Thanks Wrodnigg,
that all looks very useful.
Dave
Old 26th March 2004, 03:24 PM
wrodnigg's Avatar
CE or not CE?
Karma Power: 43
Default
Additional note:
60601-1 is currently under revision (62A/449/CDV).
Some aspects of 60601-1-4 are expected to be included in the new 60601-1 (PEMS - Programmable Electrical Medical Systems).
And maybe you are interested in a draft version of IEC 62304 (62A/446/CD) "Medical device software - Software lifecycle processes"
regards~ghw
Old 29th March 2004, 04:48 AM
Dave-h's Avatar
Karma Power: 24
Default
Thanks for the reply.
The draft of IEC 62304 looks interesting. I wonder what their plans are for the standard, as it seems to have the feel of a management systems type standard, and it uses the term "Shall" rather liberally! From a small company point of view, it is worryingly prescriptive. Certainly one to watch out for.
Dave
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Insulation diagram for a medical electrical equipment Tkerrick IEC 60601 - Medical Electrical Products Collateral Standards 4 22nd October 2009 11:53 PM
Introduction of EN 62304 - Life Cycle Requirements for Medical Device Software. alexander73 IEC 62304 - Medical Device Software Life Cycle Processes 42 11th May 2009 11:44 AM
Medical Electrical Equipment / System Peripherals - IEC 60601-1-3 freewind IEC 60601 - Medical Electrical Products Collateral Standards 16 29th September 2008 12:47 PM
Annual Safety Test for Electrical Medical Equipment temujin ISO 13485 - Medical Devices - Quality Management Systems 4 5th July 2007 02:05 PM
Refurbished and used medical electrical equipment certification Douglas Cruz Various Other Specifications, Standards, and related Requirements 9 31st August 2005 11:01 AM
The time now is 07:23 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
