Ford and Prototype and Child Parts Traceability - Requirements of Ford Q1
Are there any specific procedures or guidelines to comply with the requirements of Ford Q1 with regards to Prototype and child parts traceability and/or documentation?
I just found this site. So here it goes. Ford has a extensive book on prototyping that ends in packaging requirements. On Reporting and tracability an Inspection Report Package is prepared containing 1) PPQI Data Summary 2) Modified ISR 3) Marked-up Blue print. In a nut shell all parts must be 100% checked as per agreed upon, and all the data of the completed part and it's components (with warrants) must be sent to the SQA/SQI engineer. All parts are also serialized for tracing. Believe it or not once you follow these guidelines if used properly it can be a great benifit to both companies.
[This message has been edited by Mr Toolie (edited 05 April 2001).]
Trying to find out what Ford's requirements are for lot traceability on welded components. (ie: does the welded part need to be traceable back to the specific weld fixture of a robot?)
And if so does anyone know where I can find this information (ie specification)?
Re: Ford and Prototype and Child Parts Traceability - Requirements of Ford Q1
I apply a dot matrix code identifying the build phase and a sequential number to each prototype part which can be related to each individual inspection report.
There is no specific requirement for the child parts, but I maintain material traceability on each batch produced.
