Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st April 2004, 05:53 AM
DJN DJN is offline
E-Mails Invalid or Rejected
Registration Date: Jul 2002
Karma Power: 0
DJN has less than 100 Karma points so far.
Please Help! Internal Laboratory - Defining the Laboratory Scope - Inspection, Test, Calibration
I have been asked to write the procedure on the Internal Laboratory, but am confused. The standard says that the Lab shall have a defined scope the includes its capability to perform the required inspection, test or calibration services. Question is, how do I define that scope? What evidence would I need to supply?
Any help or guidance appreciated.
David
Sponsored Links
Old 1st April 2004, 07:29 AM
JStain JStain is offline
Registration Date: Mar 2004
Karma Power: 0
JStain has less than 100 Karma points so far.
Default Internal Lab
If I understand you correctly, they want you to define what your capable of doing. Here's a link to some examples:
http://www.a2la2.net/
This is a bit more involved, however it will give you a place to start. I've seen them as simple a a spread sheet to as complex as a Power Point Presentation.
Sponsored Links
Old 1st April 2004, 07:58 AM
sal881vw sal881vw is offline
Involved in Discussions
Thanks Given to Others: 1
Karma Power: 34
sal881vw is appreciated, and has over 300 Karma points.sal881vw is appreciated, and has over 300 Karma points.sal881vw is appreciated, and has over 300 Karma points.sal881vw is appreciated, and has over 300 Karma points.
Default
Hello DJN,
I think something like this will fit the scope..........
This technical, QMS......whatever, defines the technique used to carry out tests, calibrations........ using standard and in house methods.
You can also find valuable information by searching the web for ISO/IEC 17025
Good luck
Old 1st April 2004, 08:30 AM
DJN DJN is offline
Karma Power: 0
Default
Thanks both. That helps greatly.
Old 1st April 2004, 08:43 AM
ralphsulser's Avatar
ralphsulser ralphsulser is offline
Quality Team
Registration Date: Jun 2002
Thanks Given to Others: 87
Karma Power: 127
ralphsulser is appreciated, and has over 1700 Karma points.
ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.
Default
Dave, I have attached one of ours which be be helpful for you to see how we put it together. Hope this helps
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
"Nothing is constant except change"
Old 2nd April 2004, 01:24 AM
bpritts bpritts is offline
Involved - Posts
Registration Date: Aug 2003
Thanks Given to Others: 2
Karma Power: 38
bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.
Default
David:
The format provided by Ralph is absolutely on target.
With regard to evidence, you need to consider:
A. the written procedures (either standards or your own internal) on how
to do the procedure
B. Evidence of qualification. How do you determine that your internal
procedures work? Could be confirming a test using a 3rd party to repeat a
test as an audit
check, for example.
C. Most auditors also have special focus on training of those doing the
testing. Have your training records up to date!
Best regards,
Brad
Old 2nd April 2004, 11:53 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
David
David,
The scope provided by Ralph is good, and for an internal lab may be sufficient.
I am a bit fuzzy whether TS-16949 requires internal labs to be accredited however. Your external providers are required to be accredited to ISO/IEC 17025 so I am given to understand.
If accreditation of internal labs is required, then the scope needs more work. Places to go to look at scopes for either calibration or testing include three of the accrediting bodies that offer accreditation to ISO/IEC 17025:
http://www.iasonline.org
http://www.a2la.org
http://ts.nist.gov/htdocs/210/214/214.htm
Hope this helps.
Hershal
Old 2nd April 2004, 11:54 AM
Hershal's Avatar
Metrologist-Auditor
Karma Power: 186
Default
David,
If you need additional help, contact me off-line.
Hershal
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Expanding the Scope of a Calibration Laboratory Daniel Walker ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 10th October 2007 10:01 PM
Defining ISO17025 Calibration Laboratory Technical Competency desmond.ong ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 12th February 2007 11:16 AM
Internal Audit of Internal Calibration Laboratory - Inspection sample size question Charles Wathen Internal Auditing 2 19th May 2005 11:49 AM
Can I use a 17025 laboratory for calibration outside of their scope? sonflowerinwales ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 27th March 2005 04:30 AM
Engineers In The test Laboratory - Does this affect the Laboratory Scope? Marc ISO 17025 - Calibration, Measurement Gages and Test Laboratories 0 18th April 1999 06:21 AM
The time now is 06:59 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
