Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > Other ISO and International Standards and European Regulations
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th April 2004, 12:25 PM
apestate apestate is offline
Registration Date: Jan 2003
Thanks Given to Others: 2
Karma Power: 59
apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.
Please Help! Tolerances for cold rolled, hot rolled, DOM tubing
I think this may be more of an ASTM/SAE/ASM standard question than anything ISO, but I can relate it to our QMS here so:
We are a production hardware shop cutting parts out of 12L13, 1144, 1040, 316 stainless steel, etc. I have a detailed tolerance list from EMJ (distributor) and it references all the various AMS/SAE/ASTM, MIL standards for different material configurations.
What should I use for tolerances on cold rolled, hot rolled, DOM tubing, aluminum rod / hex / square etc, etc. Can I use this EMJ technical reference? Should I look into purchasing the standards?
Sponsored Links
Old 12th April 2004, 02:01 PM
Graeme's Avatar
Graeme Graeme is offline
$ Contributor
Registration Date: Sep 2000
Karma Power: 63
Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.
Send a message via AIM to Graeme Send a message via MSN to Graeme Send a message via Yahoo to Graeme
Default please clarify ...
Question: is EMJ your supplier, or your customer, or just someone else who happens to list technical data for the steel you use?
Graeme
Sponsored Links
Old 12th April 2004, 02:25 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Default another question
What tolerancing are you looking for...
physical size or chemical composition?
For chemical composition I would take the time to look up the standard. These issues can be critical to the end use of the product.
Carol
CarolX
Theater is life, film is art, and television is furniture.
Old 12th April 2004, 03:12 PM
Karma Power: 59
Default
EMJ is a supplier who has compiled a list of tolerances of both chemical and dimensional characteristics of the metal they sell in their technical resource. They disclaim that it is complete or up to date.
They supply the material of, for example 1144, with a material certification from the mill. The material certification is kept on file for traceability but we do not review it for chemical composition.
We check the material dimensionally to make sure we can actually run it in the machines, for condition, quantity, etc. This is all.
Do you see a need to review the material certifications for chemical composition standards?
Would it be OK to go by the EMJ list of dimensional tolerances for our incoming inspection?
Old 12th April 2004, 04:44 PM
CarolX's Avatar
Karma Power: 176
Default
I can't really answer that question...because I don't know your end product.
Nowadays, I work in a commercial sheet metal fab shop. We make all sorts of sheet metal parts for cabinets, furniture, computeres, etc. And if the skid is marked with what we ordered...great, we are good to go.
In a past life I worked for an aircraft parts manufacture. We required traceable copies of mill test reports, performed mill sampling on a quartly basis, and used the ASTM/ASME/MIL specs to defined our chemical composition requirements and tolerances.
So I guess it is up to you to define your needs and requirements, cuz it depends on what your making.
Carol
CarolX
Old 12th April 2004, 04:52 PM
SteelMaiden's Avatar
SteelMaiden SteelMaiden is offline
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
Default
As a past employee in a division that supplied EMJ with bar stock, you probably can use their tolerances and chemistry spec limits. But, if you need to be dead certain about those tolerances/chem specs for your customers, I would probably go ahead and buy the ASTM books that have the chem and size tolerances. In my experience, chemistry and size tolerances haven't changed in the 27 years I've been in the steel industry so once you had the relevant specs, you'd be good to go. There is a site(s) where you can purchase ASTM specs individually so you wouldn't have to get the entire set. One of the sites is Global Engineering Documents at http://global.ihs.com/
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
Old 12th April 2004, 05:07 PM
Karma Power: 59
Default
I believe that the specs that are relevant are included in this EMJ tech reference. I agree that the specs have not changed in 25 years and they are all listed in this book as I expect them to be.
We make parts for filtration components and devices and a broad variety of other various job shop / screw machine shop type work. We don't really have a need or capability to verify or audit material composition.
I believe using the tech resource from this distributor would be vastly sufficient for our work. The material certification documents are enough for our customers and historically there has never been a need for verifying material chemistry.
I guess I'll treat the resource guide as a controlled document and be on my merry way with this one.
SteelMaiden, would I ever be shipped out of tolerance material with an accompanying material certification sheet?
Old 12th April 2004, 05:42 PM
Karma Power: 255
Default
UMMMM, never say never...I would have to say that I seriously doubt that you'd have a chemistry problem and as long as your size tolerances are no tighter than EMJ's (they typically order to standard industry tolerance) you'll probably be fine. Unfortunately, I cannot guarantee that every facility operates at the same Cp and Cpk values that ours did. We worked long and hard to implement a very thorough SPC program and were pretty much running at 3.6 or higher for both Cp and Cpk for sizes.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Standard for surface roughness on hot rolled steel cabdriver Manufacturing and Related Processes 2 18th November 2009 04:54 AM
How to Define Scrap Metrics & Objectives - Stamped Cold Rolled Steel Fasteners juliov ISO 9001 - Quality Management Systems Standard 4 18th October 2007 02:21 PM
NCR (Nonconformance Report) for device defects - Hot rolled coils Ettore Nonconformance and Corrective Action 1 17th February 2007 11:55 AM
Resistance Welder Settings for cold rolled and galvanized steel keithm696 Manufacturing and Related Processes 3 3rd July 2006 10:56 AM
Flatness tolerances for tempered cold rolled stainless steel coils dbulak Manufacturing and Related Processes 3 30th January 2003 05:41 AM
The time now is 01:22 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
