16th April 2004, 08:04 PM
Registration Date: Apr 2004
Karma Power: 23 Karma: 10
Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc.
I am a newbie at this, and I am currently evaluating software that measures PPK, CMK, CPK, PPI, etc...
I the Old forums I've found most definitions but CMK does not appear. Anybody have a clue what it is?
By the way, does anybody have a nice, simple, cheap piece of software I can use for this purpose? So far I've only seen InfinityQS ( www.infinityqs.com)
16th April 2004, 09:13 PM
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 41 Karma: 80
First off, Infinity QS is the best software on the market to doing actual SPC (statistical PROCESS control not statistical PART control). If you are serious about statistics, it is worth the effort required to impliment. But if simple is what you want, try QualityAmerica's SPC-PC IV (I used this one for more than 10 years prior to learning about Infinity QS.
I think that Cmk is another designation for Cpm. If so, Cpm differs from Ppk/Cpk in that rather than using the nominal (middle) of the tolerance zone as the "perfect" part, the dimension is targeted at some other value to accommodate processes that are skewed by nature. Examples would include: - Tool wear (you would target your process toward one end of the tolerance and allow the tool wear to move throughout a greater range)
- Physical limitations - a die closing, parts locating in a punch press against a stop, etc
- A chemical process that uses up a reagent or catalyst
- Most GD&T designations (flatness, straightness, parallelism, angularity, perpendicularity, roundness, .....) that designate a limit are targeted toward zero.
What type of processes are you involved with?
16th April 2004, 09:49 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Cmk is defined as a capability index for a stable machine. It uses the same formula as Ppk.
Cmk is a short term study of a machine capability. Whereas Ppk is a short run study for a process.
See: http://Elsmar.com/Forums/showthread.php?t=1999
http://Elsmar.com/Forums/showthread.php?t=6804
http://Elsmar.com/Forums/showthread.php?t=1994
18th April 2004, 07:40 PM
Our Process
We are in the Maquila buisiness. Manufacture car parts, specifically automotive harnesses.
19th April 2004, 10:53 AM
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Sorry for the comment, but you are starting from the end, InfinityQS, I tink it's the most complete SPC software for now.
But for capability index almost any SPC or statistics software could do the job, it's almost a standard to obtain pp,ppk, cp,cpk and some of them cpm, cpmk and their conterparts with total variation estimate, others some more sofisticated indexes like non-parametical.
Remember that any index is just an estimate (because of the estimates of variation, the number of data in the sample, even the non normality that most of the capability index take for granted, the correctness of the specs, if is one sided or not, etc.), I my self find them usefull, but I always look for run chart (or spc chart) and histogram.
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
21st June 2004, 09:28 PM
Karma Power: 605
Hey Atul - Don't you have something along this line?
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
A question about Cpk and Cmk - Can we use Cpk to replace Cmk?
sunwen |
Capability, Accuracy and Stability - Process, Machine, etc. |
1 |
11th April 2007 08:45 AM |
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values
Howard Atkins |
SPC Monitoring and Statistical Analysis Techniques |
0 |
20th February 2006 03:41 AM |
Calculating Cpk/Ppk Simultaneously in SPC software
statman78 |
6 |
12th January 2006 01:45 PM |
Evaluating Process Stability - Unstable Processes - Cpk/Ppk?
niotusen |
6 |
31st January 2005 03:58 PM |
Cmk and Cpk - When will we need to calculate Cmk? Machine Capability
Stevenli |
3 |
20th August 2003 09:18 PM |
