10th May 2004, 01:37 PM
E-Mails Invalid or Rejected
Registration Date: Mar 2004
Karma Power: 0 Karma: 42
Linkage of ISO 9001:2000, ISO/TS16949 and Lean Manufacturing
It is my opinion from observations that there is a close relationship between ISO 9001:2000, ISO/TS16949 and Lean Manufacturing. Was I only dreaming it? I'd like someone elses take on it?
10th May 2004, 01:50 PM
Registration Date: Feb 2004
Thanks Given to Others: 1
Karma Power: 31 Karma: 152
Please share with me the similarities between ISO and Lean?
I don't see it.
ISO and TS.....yes of course. ISO is the baseline and TS is just adding the specifcs to the automotive industry. (great system)
10th May 2004, 02:08 PM
Involved - Posts
Thanks Given to Others: 16
Karma Power: 28
There is a note to clause 6.3.1 (Plant, facility, and equipment planning) that states, "These requirements SHOULD focus on lean manufacturing principles..." I think we all know, if the standard says something "SHOULD" be done then auditors will look for it. Good pick up AMR1234, the TS Standard does indeed incorporate Lean principles.
10th May 2004, 02:09 PM
Perhaps the use of word linkage is incorrectly applied. Perhaps, tools and building blocks would be more appropriate. To me, ISO/TS16949 is complimented by Lean Manufacturing, or visa versa.
10th May 2004, 02:17 PM
6.3.1 in the 9001:2000 standard ?
10th May 2004, 02:41 PM
lean vs ISO
9001:2000 = conformity to requirements
Lean = deliver value at the least cost
ISO procedures, audits, and all the other documentation = NON VALUE
TS and ISO are going in the right directions. The supplier 8D is a great system used in lean and TS. The focus on processes in the 9001:2000 is part process mapping.
10th May 2004, 02:45 PM
Involved - Posts
Karma Power: 28
No...6.3.1 in TS 16949. It is a supplement to ISO 9k2k.
10th May 2004, 02:56 PM
yes I know. I passed a registartion audit last month.
But I thought the question was also about ISO 9001:2000, maybe I was wrong. ,
